bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
So. The real seal is probably out since the leak comes out between the motor and transmission, and it's not gear oil.
Here's a list of parts I think I'll probably need while I'm down there. What am I missing or should look at replacing? Rear Seal Motor Mounts - tranny mounts look good Spring washers on CV joint bolts Cone screws for Shifter Bar |
McMark |
You can reset your endplay on the crankshaft.
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
O-ring for flywheel and flywheel shim seal or whatever you call it.
Ball cup for clutch fork? Emery cloth for the flywheel to the main seal. |
McMark |
QUOTE flywheel shim seal or whatever you call it Rear main seal. (IMG:style_emoticons/default/biggrin.gif) |
PRS914-6 |
Excellence Magazine Project 914 3.6 ![]() ![]() ![]() Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None ![]() ![]() |
Probably going to need a clutch disk, it's most likely oil soaked. Throw out bearing if needed. Replace the clutch arm ball cup and set the proper amount of shims under the pivot ball to get the arm geometry correct.
bandjoey |
You guys are really making my day (IMG:style_emoticons/default/hissyfit.gif) but if I break it apart, I guess that the right way. Parts are Parts, unless they're on a 914.
I'm going t make bumper stickers: It's Finished! Until something else quits. (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 25th June 2024 - 10:04 PM |
