Type 47 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 783 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None ![]() ![]() |
Just got a 75 2.0 that has had dual Webbers replace the fule injection...
Do carb conversions require a different cam? do just bolting on carbs do the trick? |
jimkelly |
Delaware USA ![]() ![]() ![]() ![]() Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region ![]() |
good advice below.
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,475 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
Carbs require a different cam to run *at their best*. But the car will run on the stock cam using dual carbs. You will just be leaving power on the table.
Zach |
ME733 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 842 Joined: 25-June 08 From: Atlanta Ga. Member No.: 9,209 Region Association: South East States ![]() |
.As you just got the car, ....sort it out first. optimize the carburator settings and jetting...for that camshaft/piston cylinder, head combination...optimize the ignition timing...the "OEM" stock camshaft works with fuel injection, and will work just fine with carburators with a little tuning.Carburator CAMS will have more duration,(and generally) more lift, which is why they work better,produce more H.P., and at higher rpms........optimize what you have first.
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
QUOTE Carbs require a different cam to run *at their best*. But the car will run on the stock cam using dual carbs. You will just be leaving power on the table. (IMG:style_emoticons/default/agree.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 08:21 AM |
