LotusJoe |
Europa Twink Driver ![]() ![]() Group: Members Posts: 406 Joined: 30-November 09 From: Southern California Member No.: 11,085 Region Association: Southern California ![]() |
I'm in the process of rebuilding all four brake calipers and am contemplating having them cadmium plated. Does anyone know if the plating process will require that the bores be re-polished. I'm thinking that since the o-ring sits in the caliper and if the piston is smooth with no pitting; that as long as the bore is clean and free of any gouges that the plating process will have little effect.
Any thoughts or experience is appreciated. Thanks |
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
This guy would know for sure
http://www.pmbperformance.com/catalog/item...552/4782980.htm |
drgchapman |
Current Stable ![]() ![]() ![]() Group: NoClassifiedAccess Posts: 922 Joined: 20-September 04 From: Portland, OR Member No.: 2,789 Region Association: Pacific Northwest ![]() |
Eric will chime in shortly.......
underthetire |
I hope so. Can't use his checkout thingy on the web site.
jmill |
Green Hornet ![]() ![]() ![]() ![]() Group: Members Posts: 2,449 Joined: 9-May 08 From: Racine, Wisconsin Member No.: 9,038 Region Association: Upper MidWest ![]() |
You'll most likely get them zinc plated. Not too many places do cad plating anymore.
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
I can see Eric is typing right now. But I learned at the last WCR that zinc is OE. (IMG:style_emoticons/default/cool.gif)
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
The good news is, ATE zinc plated them... not CAD.
The better news is, you won't need to hone them once they're plated. the bores should come back smooth and clean. What's wrong with the checkout thingy? |
underthetire |
Kept waiting for some secure check out. Ill call you tomorrow.
Eric_Shea |
We use "authorize.net"
Fairly standard for secure checkout. Is it hanging? I tried a test order and everthing was fine. |
tradisrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California ![]() |
i painted mine and while they look good I wish I had them zinc plated....
underthetire |
I just bought a rebuilt zinc plated one at the swap meet I have to paint.. (IMG:style_emoticons/default/barf.gif)
underthetire |
We use "authorize.net" Fairly standard for secure checkout. Is it hanging? I tried a test order and everthing was fine. Worked today. Not yesterday. Now go get my lines (IMG:style_emoticons/default/slap.gif) |
LotusJoe |
Thanks for the info guys. Will let you know how it turns out.
Lo-Fi Version | Time is now: 26th June 2024 - 08:16 AM |
