Zaney |
Deuchland en der Haus ![]() ![]() Group: Members Posts: 461 Joined: 1-March 04 From: Engine 11 Redmond, WA Member No.: 1,738 Region Association: Pacific Northwest ![]() |
Could someone who has already purchased the Bremar aluminum plate please measure the thickness of the plate and, post the thickness.
Thanks! |
rickthejetman |
Member ![]() ![]() Group: Members Posts: 90 Joined: 5-May 09 From: victorville ,ca Member No.: 10,335 Region Association: None ![]() |
Could someone who has already purchased the Bremar aluminum plate please measure the thickness of the plate and, post the thickness. Thanks! i made my own out of 1/8" plate from the pics i saw of theres it looked to be around 1/4" but i figured they made it that thick because of the machined in logo. |
Zaney |
Could someone who has already purchased the Bremar aluminum plate please measure the thickness of the plate and, post the thickness. Thanks! i made my own out of 1/8" plate from the pics i saw of theres it looked to be around 1/4" but i figured they made it that thick because of the machined in logo. Would you mind posting pics of your finished plate? Thanks for the info! |
BIGKAT_83 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,799 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States ![]() ![]() ![]() |
Here you go....
![]() Bob |
rickthejetman |
Could someone who has already purchased the Bremar aluminum plate please measure the thickness of the plate and, post the thickness. Thanks! i made my own out of 1/8" plate from the pics i saw of theres it looked to be around 1/4" but i figured they made it that thick because of the machined in logo. Would you mind posting pics of your finished plate? Thanks for the info! sure i'll take a pic when i get home from work. |
strawman |
Senior Member ![]() ![]() ![]() Group: Members Posts: 888 Joined: 25-January 08 From: Los Osos, CA Member No.: 8,624 Region Association: Central California ![]() ![]() |
Could someone who has already purchased the Bremar aluminum plate please measure the thickness of the plate and, post the thickness. Thanks! I just measured mine, and it is 0.32". But I don't think the thickness is critical, since it only appears to be keeping the gear oil in. Post pics when your plate is done! |
charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
I agree it's just a cover plate but I would make it at least 1/4 thick just so it will seal good at the flange. It is probably 8mm or .3144 from bremar.
Zaney |
So, I took the pictures and advice from the members here and went to Everett Steel to see if they had a piece of aluminum in their remnant pile. Luckily, they had a 9 x 11 inch piece of 1/8 inch thick aluminum with someone's sign of "W.W.J.D". I think he would DIY! (IMG:style_emoticons/default/biggrin.gif)
![]() Then, instead of using the poster board I cleaned up the nose cone and traced it directly to the cleaned up piece of aluminum. ![]() I used these tools to make the plate from a $4.68 piece of aluminum (IMG:style_emoticons/default/piratenanner.gif) ![]() |
Zaney |
Next, i carefully drilled pilot holes in the plate and then chased them with the step drill bits to get the holes close.
I used a bolt to gauge how big the holes would be in the plate so I did not drill too big! For the shifter arm, drilled a hole in the plate then used a carbide drill bit to open up the hole to the traced dimensions. (IMG:style_emoticons/default/sawzall-smiley.gif) Then, after all the holes (including the drift pin holes) were finished I used various metal cutting blades in my jigsaw to cut out the plate. ![]() After I was close to the traced out lines I test fit the plate on the end of the trans. ![]() It took a bit of feathering with the step drill bits and emery cloth to get every hole aligned properly. But it worked out great! ![]() |
Zaney |
I am very pleased with the outcome of this DIY plate! (IMG:style_emoticons/default/smilie_pokal.gif)
I had to go out and buy new bolts and hardware for the plate (20mm bolts instead of original 40mm in length) that came to $6.50. So, instead of forking out $350 or so for the Bremar Kit I spent $11.00 and used 3 cutting wheels for the DIY Coupling. So, here are the results! ![]() And the final plate pic with silicone sealant on the trans to make it tight!!! ![]() I recommend this method to anyone who wants to save $350 for the rest of their Suby project! Especially, coming from a novice like myself! Cheers, Nate |
strawman |
Atta boy!!!
jpnovak |
They call me "Nanoman" ![]() ![]() Group: Members Posts: 231 Joined: 26-August 09 From: Austin TX Member No.: 10,736 Region Association: Southwest Region ![]() |
Glad to see my method of cutting the diff works.
I made the same aluminum plate from a 3/16" scrap I found in the garbage behind an industrial strip center. If you don't mind a little smell and dirt you can find things as good as gold. |
Lo-Fi Version | Time is now: 19th April 2025 - 03:10 PM |
