> How to repair Tach Bouncing/Dampening?, Can't find the thread
Eddie914
post Jun 17 2010, 12:36 PM
Unregistered
The tach on my 914/6 (conversion) has lost it's dampening. The tach needle is nice and steady as long as the engine rpm is constant. When the rpm changes quickly (such as when gear changes are made), the needle bounces. It takes a fews seconds to settle.
I remember reading a thread about adding a resistor to the circuitry to repair the problem.
Even though a 3.2 six has been installed in the teener the engine electronics and induction are still "old school" ... 40mm Weber carbs and points, condenser & CDI ignition. The tach is an early 70's 911 model with a 7,200 rpm redline.
Can anyone help me out/
Thanks
Eddie
detoxcowboy
post Jun 17 2010, 01:40 PM
Region Association: Africa
http://nhspeedometer.com/914/1.htm
North Hollywood Speedo installs them.. did mine and it works perfectly
underthetire
post Jun 17 2010, 02:35 PM
I remember that too. It was a capacitor though,not a resistor. I can't find it anymore either.
underthetire
post Jun 17 2010, 02:43 PM
Now I remember, the resistor was kind of a fake out to run V8's and use the stock tach. The bouncing problem was a dried up I think 1UF capacitor inside the tach. Thats bouncing during RPM changes. Bouncing tach all the time was points/or alternator/or VR going bad.
dr914@autoatlanta.com
post Jun 17 2010, 03:01 PM
If it has lost it suddenly but worked before it may just be dirty contact points. However Palo Alto has added ballest to tachs that we have had converted without having to find the very expensive three blade capacitor installed on the factory six relay boards.
QUOTE(Eddie914 @ Jun 17 2010, 11:36 AM) *
Thanks
Eddie
Michael N
post Jun 17 2010, 08:28 PM
Certifiable
I think this is the link. Bouncing Tachometer Link I soldered in a capacitor and it dampened my old tach about a year ago. At first I went too much dampening and the tach was too slow to respond to the revs. I then changed to a different capacitor and the tach is now perfect. Spokes photo in post #7 helped a bunch.
Eddie914
post Jun 18 2010, 09:23 AM
Unregistered
Thank you everyone!
You are the best!
Eddie
- Lo-Fi Version Time is now: 4th January 2025 - 06:44 PM
