JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,580 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
The oil temp sender/gauge circuit is a green wire with black stripe.
For 1970-71 the oil temp sender connection is on the ignition harness then goes through the relay board and chassis harness presumably to the dash guage cluster. For 1973-76 the oil temp sender connects to a single wire branch in the main harness below the battery. For 1972 there is no green/black wire in the ignition harness and one 1972 owner has told me there is no green/black connection under the battery on the chassis harness like the later cars. The 1972 model also does not have the center console wiring branch on the chassis harness. So how is the oil temp sender connected to the oil temp guage for 1972, and is the oil temp guage supposed to be located in the dash? Help! |
dr914@autoatlanta.com |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,914 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None ![]() |
There is not one. You must run an additional wire.
The oil temp sender/gauge circuit is a green wire with black stripe. For 1970-71 the oil temp sender connection is on the ignition harness then goes through the relay board and chassis harness presumably to the dash guage cluster. For 1973-76 the oil temp sender connects to a single wire branch in the main harness below the battery. For 1972 there is no green/black wire in the ignition harness and one 1972 owner has told me there is no green/black connection under the battery on the chassis harness like the later cars. The 1972 model also does not have the center console wiring branch on the chassis harness. So how is the oil temp sender connected to the oil temp guage for 1972, and is the oil temp guage supposed to be located in the dash? Help! |
realred914 |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None ![]() |
There is not one. You must run an additional wire. The oil temp sender/gauge circuit is a green wire with black stripe. For 1970-71 the oil temp sender connection is on the ignition harness then goes through the relay board and chassis harness presumably to the dash guage cluster. For 1973-76 the oil temp sender connects to a single wire branch in the main harness below the battery. For 1972 there is no green/black wire in the ignition harness and one 1972 owner has told me there is no green/black connection under the battery on the chassis harness like the later cars. The 1972 model also does not have the center console wiring branch on the chassis harness. So how is the oil temp sender connected to the oil temp guage for 1972, and is the oil temp guage supposed to be located in the dash? Help! me too, got two 72 cars, both need the wire added. |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
tradisrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California ![]() |
i don't think my '70 has a oil temp wire. I ran my own, but now i'm going to look for the wire....
jsaum |
Senior Member ![]() ![]() ![]() Group: Members Posts: 530 Joined: 12-June 07 From: Everett, WA Member No.: 7,809 Region Association: None ![]() |
I'm looking at installing a center console in my 72. I have the taco plate and sending unit for the oil temp gauge and just picked up a gauge set. I was wondering if anyone makes a wiring harness for a retro fit?
Jsaum |
Lo-Fi Version | Time is now: 1st July 2024 - 05:11 AM |
