East coaster |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,700 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None ![]() ![]() |
I'm considering selling my 914 (can't believe I'm typing this!). I've owned 12 914's over the years and built this to be my idea of the ultimate streetable 914. My goal was to make it as close to looking like it came from the Factory as possible with an updated flavor.
There are many pics and info on this site about my build process but here's the high level details: Base car was a 1974 Factory Silver 1.8 that had 42K miles and was stored in a temp controlled environment for 18 years. The car was stripped to bare metal, Steel GT flares butt welded and any rust was addressed (still has factory battery box!). An Engman stiffening kit was welded to strengthen the frame and it was given a bath in Glasurit GT silver paint. A zero mile 3.6 six was installed utilizing a Patrick Motorsports bulkhead mount (welded). The 3.6 retained all the factory injection and electronics and runs primo. The stock intake was flipped, so no sheet metal was cut to make stock Injection fit. It breathes out through a set of Jet-Hot coated 1-3/4 European Racing Headers and a custom muffler with Boxster style center tip. The tranny is a 915 with every WEVO goodie available at the time (shift gate, bearing plate, 914 conv, etc..). It also has a factory limited slip installed and is actuated via a Rennshift lever. The cooling system is rather unique in that it utilizes a front cooler with a fiberglass plenum to channel fresh air into the cooler and hot air out through the sides of the wheel wells. It is very efficient and I've never seen the temps go anywhere near the red even when stuck in traffic on a 100 degree day. The suspension is Carrera front end with Tarret sway bar and Koni adjustable shocks and the rear is stock with Koni adjustables and 165lb variable rate springs and includes a factory rear sway bar that I never installed but all body bracketry was welded for it. The rear rotors are early 914 (multi-pattern style) that were professionally drilled for 911 pattern. The wheels are 7x7 front and 7x9 rear and are factory units from a 2003 911. The tires are Continentals and should be replaced soon. The interior was treated to a set of glove leather heated GT racing seats and a 911 style dash. It has an after-market center console that houses the Stereo (Kenwood head unit w/Polk speakers) and a custom 10" sub-woofer enclosure incorporated into the passenger footwell that does not impact passenger comfort. The Sound system is about as good can be expected in a 914. It's finished off with a Momo leather wheel and brushed stainless dash accents. It's modern looking, but not too far over the top (my opinion). As in most projects, there's a couple things I never got to before driving it became a distraction. I never hooked up the electronic speedometer, I never hooked up the heated seats, although I did run a 12v bus to power them. I also never hooked up the driving lights. It is wired for them from the factory and the factory switch is installed, so I'm not sure why I never did it...oh well! The only other item that comes to mind is the backpad. It is currently just painted silver and I've been OK with that, but had always planned on covering it with something some day. The car drives, runs, and handles excellent. The only problem I know of is a weird thing with the alternator light where it comes on at 3800 rpms and stays lit until you turn the car off. This began when I replaced the alternator a couple years ago. It doesn't seem to have any ill effects and the Alt seems to work fine. Some folks suggested it could be a funky regulator but that's pure speculation. It also has a blemish on the passenger side sail panel near the door handle. It looks like a rust bubble but it came up about week after painting and it hasn't changed shape/size in 4 years, so I doubt it's rust and more likely a chemical reaction of some sort. This area was bare metal and clean prior to painting, but assume rust and be happy when it's not! The area is about the size of a pea. I'm entertaining offers over $25K. If you ever try to build a car like this your budget will far exceed that, maybe by double! ![]() |
East coaster |
East coaster |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,336 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
I'm halfway through a similar project. If I knew then what I knew now, I would have bought your car in a second. I'm sure it cost double to build even being careful with budget. Vinyl on the targa sail panel might cover up the paint blemish. I’ll be near Atlantic city in 2 weeks. Any chance I could take a look? Thanks, Mark
East coaster |
East coaster |
East coaster |
wes |
wes ![]() ![]() ![]() Group: Members Posts: 1,589 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California ![]() ![]() |
Im in love, Well done, If I had the $$
kerry kohn |
I'm new here ... Group: Members Posts: 0 Joined: 21-July 10 From: chicago, illinois Member No.: 11,963 Region Association: Upper MidWest ![]() |
Great job. Very interested. Please e-mail me your contact number.
championgt1 |
Don't embarrass me Filmore! ![]() ![]() ![]() ![]() Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest ![]() |
One of my favs. Love this car!! (IMG:style_emoticons/default/drooley.gif)
saul |
I'm new here ... Group: Members Posts: 0 Joined: 21-July 10 From: Calgary Member No.: 11,964 Region Association: None ![]() |
Beautiful car!!! I'm very interested, please e- mail your phone #. Not a tire kicker.
Mountain914 |
Too much time in thin air! ![]() ![]() Group: Members Posts: 367 Joined: 22-May 03 From: Conifer, CO Member No.: 725 Region Association: Rocky Mountains ![]() |
Daaaaaang ! Methinks you aren't asking enough, but the market will decide. Awesome car!!! I haven't driven a 3.6 setup, I like the balance of power and weight with the 3.0, this thing must be POW-erful! I make up for the difference by painting mine yellow (ha-ha).
Nice job - and if you can't believe you're typing a for sale post - you will defintely regret selling it even more so! |
i love porsche |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,547 Joined: 6-May 04 From: Nutley, NJ Member No.: 2,030 Region Association: North East States ![]() |
im drooling...if only it was in my budget!
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,860 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
Just a spectacular 914; it is in my budget.... unfortunately a divorce isn't so I will have to just be content with my six that will need $30K to put together. Best wishes and some lucky SOB is going to have a wonderful car.
U N S E E N |
Newbie ![]() Group: Members Posts: 6 Joined: 16-November 09 From: El Paso TX Member No.: 11,048 Region Association: Southwest Region ![]() |
Wow that is just breath taking. Perfection. GLWS (IMG:style_emoticons/default/pray.gif)
East coaster |
I've had many inquiries and I will respond to all. I was trying to see if there was interest in the car and it seems their certainly is! For all the folks who've tried to contact me, I apologize for my delayed response but I've had a very busy work week.....I will respond to all inquiries. I stated I'll entertain offers over $25K and now I need to figure out how to navigate through those offers and settle on a deal.
Thank you for all the interest and kind comments on the car...it really is an awesome 914 to drive. It's a shame the factory didn't have the 3.6 when they designed the 914...the torque is wonderful in this car. |
budman5201 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 595 Joined: 1-April 07 From: tempe, az Member No.: 7,635 ![]() |
I've had many inquiries and I will respond to all. I was trying to see if there was interest in the car and it seems their certainly is! For all the folks who've tried to contact me, I apologize for my delayed response but I've had a very busy work week.....I will respond to all inquiries. I stated I'll entertain offers over $25K and now I need to figure out how to navigate through those offers and settle on a deal. Thank you for all the interest and kind comments on the car...it really is an awesome 914 to drive. It's a shame the factory didn't have the 3.6 when they designed the 914...the torque is wonderful in this car. Attached image(s) ![]() |
howell914 |
Newbie ![]() Group: Members Posts: 39 Joined: 25-January 06 From: ct. Member No.: 5,472 ![]() |
Did this car sell??
caceo |
I'm new here ... Group: Members Posts: 0 Joined: 11-July 10 From: bellingham Member No.: 11,923 Region Association: None ![]() |
(IMG:style_emoticons/default/aktion035.gif)
Great job..... I am totally wrapt! This is one of the best..... Great work~ |
spare time toys |
hooked on grilling food. ![]() ![]() ![]() ![]() Group: Members Posts: 4,059 Joined: 3-April 04 From: West Plano Tx Member No.: 1,884 Region Association: Southwest Region ![]() |
Just bumpn a nice car TTT (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 28th June 2024 - 09:19 PM |
