Corkus |
Newbie ![]() Group: Members Posts: 22 Joined: 14-June 10 From: N. Calif & S. AZ Member No.: 11,834 Region Association: None ![]() |
Currently have:
2000 Subaru Legacy donor car EJ25 165 hp/165 foot-lbs torque engine Subaru axles 914 Hubs 4 lug wheels 914 CV Joints Bremar Kit installed Questions: Am I ok with the 4 lug wheels and 914 hubs? Are they strong enough for this drivetrain assuming I don't modify it for more power? I had Riveria wheels on my 914 in the 70's and kind of want them on this car if they are strong enough. I am expecting to take those long Subaru axles to a machine shop and have the outboard ends machined to accept 914 CV's/hubs. Am I right? And where do I get this kind of machine work done? Any suggestions? Thanks all. |
1968Cayman |
Redacted by Irving Washington ![]() ![]() Group: Members Posts: 116 Joined: 5-February 10 From: Holly Springs, GA Member No.: 11,332 Region Association: South East States ![]() |
I'm having mine sent to Dutchman Motorsports. Using everything you're suggesting.
BIGKAT_83 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,799 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States ![]() ![]() ![]() |
I'm having mine sent to Dutchman Motorsports. Using everything you're suggesting. Had Dutchman do the work for me also. I used 911 axles and had them cut for the subaru inter CV. The 911 axles are far bigger diameter than the subaru axles. I have also found a shop in the Atlanta area that can do the work at about half the price Attached image(s) ![]() |
1968Cayman |
I'm in the Atlanta area- do tell!! Who can do the work?
nsyr |
Because I Can ![]() ![]() Group: Members Posts: 314 Joined: 16-May 04 From: Tampa, FL Member No.: 2,073 ![]() |
what is the cost for something like this?
1968Cayman |
Think I'm paying $125 for the machine work to both axles.
charliew |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,363 Joined: 31-July 07 From: Crawford, TX. Member No.: 7,958 ![]() |
I assume by both axles as in suby axles or have you switched to 911 axles?
Lo-Fi Version | Time is now: 19th April 2025 - 06:31 AM |
