PeeGreen 914 |
Just when you think you're done...wait, there is more..lol ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,219 Joined: 21-September 06 From: Seattle, WA... actually Everett Member No.: 6,884 Region Association: Pacific Northwest ![]() ![]() |
Need to get a new battery for a 914 today and recall the 34r works but the 35 is better? Is it just the 35 or is it the 35r?
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
Don't know which is better but there pretty cheap at Costco.
PeeGreen 914 |
Don't know which is better but there pretty cheap at Costco. I get them at cost from the distributor. Thanks though, I'm sure someone needs to know that (IMG:style_emoticons/default/beerchug.gif) |
RFoulds |
Green Teen 66 ![]() ![]() ![]() Group: Members Posts: 837 Joined: 10-August 09 From: La Quinta, CA Member No.: 10,656 Region Association: Southwest Region ![]() ![]() |
Come on everyone! I need to know this too! Which Optima Battery is the correct fit for the 914????
I do need to buy one today. and was going to post this as well. (IMG:style_emoticons/default/smile.gif) (IMG:style_emoticons/default/biggrin.gif) |
mepstein |
I had a thread on this a couple months ago and the consenses was both will probably work. They have almost the same dimentions and as long as your battery cables will reach then you are good. The Costco in my area only carried a 35.
kkid |
Member ![]() ![]() Group: Members Posts: 343 Joined: 18-December 07 From: Oakland, CA Member No.: 8,483 Region Association: Northern California ![]() |
Check this site and you will get an answer you want.
http://www.1st-optima-batteries.com/index.html I got 35. It's much lighter than 34/34R and negative post is closer to the firewall and can be under the rain tray. |
kkid |
Forgot to mention, you need an adapter to install 35. It comes with a battery for free if you request. Don't know if 34 needs the adapter though.
RFoulds |
thanks. what does the adapter do?
tod914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 ![]() |
35 is slightly smaller and about 8 pounds lighter if I recall. That's what's in my current car. Prefer it over the 34R. The 35 and 34R have the terminals in the same location.
Vysoc |
Vysoc ![]() ![]() ![]() Group: Members Posts: 586 Joined: 27-August 09 From: Young Harris, Georgia Member No.: 10,737 Region Association: South East States ![]() |
I have purchased two Red Top 35's from Costco. First one was for my 911SC, I fabricated a bottom brace from a simple piece of 1" angle to help snug down the battery. The 35 fit fine in the 914, It does not appear to be moving around but I need to make the base fit a little bit more snug. I will mess with some custom pieces to really secure it. Vysoc (IMG:style_emoticons/default/rolleyes.gif) |
PeeGreen 914 |
The 35 just showed up at the shop. I will be picking it up tonight after I get off work. I was just told it came with a few plastic pieces so maybe it now automatically comes with something to make it fit. (IMG:style_emoticons/default/confused24.gif)
I'll let you know. |
Lo-Fi Version | Time is now: 25th June 2024 - 07:56 PM |
