BKLA |
Really old member ![]() ![]() ![]() Group: Members Posts: 1,253 Joined: 14-August 05 From: OR Member No.: 4,590 Region Association: Pacific Northwest ![]() ![]() |
Camp914 offered these assemblies for a short while. See original link
Mike Swanson at AR Concepts still makes the 914 R light fixtures. $170.00 for the fixtures only as of 9.09.2010. (Left & right side) - According to Mr. Swanson, solid color lens knock offs are available (solid red or soild amber - no split lenses) for about $25.00 each - depending on the number ordered. (These come from an Australian manufacturer.) - The hella lights vary from $45 - $60 EACH (4 total) at various dealers and through AR Concepts. This includes the original split lens fixtures. Contact: Mike Swanson AR Concepts ar_concepts@hotmail.com (818) 470-5700 on a separate note: Automotion.com has a 911R assembly with lights... ![]() Available with either a half amber / half red outside turn signal light and solid red inside running/brake light or half amber / half white (reverse light) outside turn signal lamp with solid red inside running / brake light. You may be able to order the lights only in a configuration that you want. |
BKLA |
Hella light fixtures here:
http://www.rallylights.com/detail.aspx?ID=2520 ![]() Thanks to series9 for the info! |
Lo-Fi Version | Time is now: 29th June 2024 - 04:22 PM |
