DAPO Pictures, Things that make you go hummmmm!!!!!! |
914Sixer |
Sep 18 2010, 07:09 PM
914 Guru Group: Members Posts: 9,019 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I bought a z-green 74 and am in the process of sorting it out to run. I am replacing everything that is missing and not correct. I started sorting out the fuel injection and found the fuel pump moved to the front of the car with a piece of zip cord run through the tunnel from the rear to power the pump. All of this was mounted on the front suspension pan cover.
Wonder why this door rotted out? It is completely covered with 1/2 " carpet pad. Every surface had pad glued down including the bottom of the door where the drain holes were. Both door were done like this. Back wall had same carpet pad behind the molded wall. Attached image(s) |
PanelBilly |
Sep 18 2010, 07:40 PM
914 Guru Group: Members Posts: 5,860 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I think the saddest part is that the DAPO thought he was improving the car
dlee6204 |
Sep 18 2010, 08:57 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
Oh my... (IMG:style_emoticons/default/icon8.gif)
70_914 |
Sep 18 2010, 10:20 PM
Member Group: Members Posts: 395 Joined: 4-December 09 From: Roy, WA Member No.: 11,096 Region Association: Pacific Northwest |
20 years from now there will be a thread showing pictures of rusty 914's with dynamat all over them and the comments will be the same...
Just sayin'... |
bembry |
Sep 19 2010, 03:07 AM
Senior Member Group: Members Posts: 529 Joined: 29-July 05 From: Bakersfield, CA Member No.: 4,499 Region Association: MidAtlantic Region |
Well, if the comments fit. . . .
carr914 |
Sep 19 2010, 04:28 AM
Racer from Birth Group: Members Posts: 122,057 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
20 years from now there will be a thread showing pictures of rusty 914's with dynamat all over them and the comments will be the same... Just sayin'... I don't agree. That carpet foam was just a sponge that held water and Mark said the drain holes were plugged. Dynamat doesn't hold any water. Also I think that any 914 that is being restored today will most likely be stored in a garage vs outside in the elements for the last 40 years. |
CptTripps |
Dec 17 2013, 10:44 AM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
I know I'm digging up an old thread...but this seemed like the most appropriate place to show these gems off.
"I don't have a half-inch bolt....lets use a four-inch bolt with an assortment of washers." (I didn't think this bolt would ever end.) "I'm not sure what this is. Just wrap it in duct-tape, copper pipe insulation, and some zip-ties." (Used as a hood release.) "Hmm....a cork. Yeah...that's the ticket!" (I love that there are two washers on either side of this...) |
Mblizzard |
Dec 17 2013, 10:52 AM
Beaded lamp pull chain must meet all of the structural requirements for use as a throttle cable! Right?????
monkeyboy |
Dec 17 2013, 10:58 AM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
I wonder how many of us have a background in VW ownership... When I was buying and selling bugs, all that stuff was par for the course. You expected to see something hacked up.
Steve Snyder |
Dec 17 2013, 01:11 PM
Member Group: Members Posts: 241 Joined: 10-June 08 From: Graham, NC Member No.: 9,158 Region Association: South East States |
monkeyboy |
Dec 17 2013, 04:39 PM
exactly.
rhodyguy |
Dec 17 2013, 06:15 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,192 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
facet fuel pump mounted on the pass side engine tin inside the engine compartment and plumbed with cloth (deteriorated) covered fuel line.
CptTripps |
Dec 18 2013, 07:13 AM
From the "Department of Redundancy Department"
Same number of tap-screws on both sides. I guess they had the screws. Why not use them all? Attached thumbnail(s) |
Chris H. |
Dec 18 2013, 07:34 AM
Senior Member Group: Members Posts: 4,048 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Wow...those need to go in the "bad parts museum". The cork piece is a work of art! And the original one? The carpet in the door? That door had to weigh a TON when it rained. Although the lamp chain.... (IMG:style_emoticons/default/idea.gif)
Wish I still had pics of my '73 2.0 parts car from waaay back. The sail panels were repaired with black tar and then roofing material over the top (tar paper I think...). It wasn't a BAD job...didn't realize it until I took the near-perfect trim pieces off.... |
mikesmith |
Dec 18 2013, 10:43 AM
Member Group: Members Posts: 202 Joined: 5-September 13 From: SF Member No.: 16,354 Region Association: Northern California |
From the "Department of Redundancy Department" Same number of tap-screws on both sides. I guess they had the screws. Why not use them all? That looks like Renegade's work; everything I touch is slammed into the body with tek screws (or fat-head rivets). Even their cable shifter is just tek'ed to the centre tunnel. |
ripper911 |
Dec 18 2013, 02:29 PM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
I wish I would have gotten a picture of my 911's seatbelt receivers while they were still in the car, some DAPO attached them to the car with bondo.
smj |
Dec 18 2013, 02:52 PM
"Dude, Steve from Berkeley." Group: Members Posts: 591 Joined: 28-August 05 From: Berkeley, CA Member No.: 4,691 Region Association: Northern California |
914Sixer |
Dec 18 2013, 05:36 PM
It is good to see the handy work of FORMER rocket scientists in action.
CptTripps |
Jan 17 2014, 04:34 AM
Here's another good one.
Looks like 3 attempts at getting the spoiler in the right place...and then a tube of silicone was used without ever touching the fiberglass. Kinda like a "reverse moat" around the holes. Attached thumbnail(s) |
carr914 |
Jan 17 2014, 07:05 AM
Lo-Fi Version | Time is now: 26th November 2024 - 01:46 PM |
