rwilner |
No Ghosts in the Machine ![]() ![]() ![]() Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States ![]() |
So I finally got my heat back on the car last night, but I'm unclear how to connect the little mechanical cable to the flapper valve.
It looks like a barrel bolt or something is missing? Where can I get the correct fastener -- is something available at the hardware store? Thanks! Rich |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
A barrel bolt which I don't think you'll find at the hardware store.
![]() Wow! $10 at Pelican... (IMG:style_emoticons/default/dry.gif) |
rwilner |
Jim
Is that bold threaded at one end to accept a screw, which presses against the cable end? Trying to envsion how it works. thx Rich |
tradisrad |
Senior Member ![]() ![]() ![]() Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California ![]() |
the cable goes through the hole in the middle and the screw (missing in pic) goes in from the end. similar to the throttle cable (maybe same part)
rwilner |
slu234 |
Member ![]() ![]() Group: Members Posts: 57 Joined: 20-January 09 From: Staunton, VA Member No.: 9,949 Region Association: MidAtlantic Region ![]() |
the cable goes through the hole in the middle and the screw (missing in pic) goes in from the end. similar to the throttle cable (maybe same part) That's what i figured. Anyone have an extra one??? You can get them at the car parts store (Advance, AutoZone). I believe that they were in a box of 4 and labeled as accelerator cable connector (not sure why you would need four of them) (IMG:style_emoticons/default/confused24.gif) Brian |
Tom_T |
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California ![]() ![]() |
Common VW part also, you'll see them for much less at VW suppliers - both barrel nut & screw, or at the usual sources SMC, AA, GPR?, PP/Automotion, TC'sGarage, & yes Peli - as well as on TheSamba, evil-bay, etc.
$10 as a "Porsche" part vs. something like $2 for the "VW" part - nut/screw - or whatever $'s at FLAPS (IMG:style_emoticons/default/idea.gif) |
rwilner |
Common VW part also, you'll see them for much less at VW suppliers - both barrel nut & screw, or at the usual sources SMC, AA, GPR?, PP/Automotion, TC'sGarage, & yes Peli - as well as on TheSamba, evil-bay, etc. $10 as a "Porsche" part vs. something like $2 for the "VW" part - nut/screw - or whatever $'s at FLAPS (IMG:style_emoticons/default/idea.gif) Going to try NAPA on the way home. Wish me luck |
bandjoey |
bandjoey ![]() ![]() ![]() ![]() Group: Members Posts: 4,929 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region ![]() |
Autozone has about 2-3 sizes in a bag for a few $'s.
rwilner |
Lo-Fi Version | Time is now: 18th June 2024 - 06:24 AM |
