Found the "standards" for aftermarket wheels !!! |
Mueller |
Apr 20 2004, 05:59 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
It appears that SEMA Spec 5-1A has been replaced by SAE J2530.
(I talked to someone from SEMA) So, I joined SAE and downloaded the specifications for Aftermarket Wheels....ouch!!!! $45.00 for 9 .pdf pages (IMG:style_emoticons/default/sad.gif) I'm sure someone will tell me that I could have found this for free knowing my luck (IMG:style_emoticons/default/wink.gif) It does have all the information on what should be stamped/marked on the wheels*, test and procedures need to be performed as well as the engineering formulas to figure out the Bending Moment and the Radial Load, interesting stuff........... *manufactures name or trademark, part number, country, wheel load rating and something new I've never seen on a wheel=largest diameter tire at it's maximum rated inflation |
TimT |
Apr 20 2004, 06:20 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
Mike on the other other thread I steered you to SAE (IMG:style_emoticons/default/cool_shades.gif)
jonwatts |
Apr 21 2004, 12:20 AM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
Did you need the spec for the water-cooled rims or for the 3-piece heads? (IMG:style_emoticons/default/wacko.gif)
maf914 |
Apr 21 2004, 06:31 AM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
QUOTE(jonwatts @ Apr 20 2004, 10:20 PM) Did you need the spec for the water-cooled rims or for the 3-piece heads? (IMG:style_emoticons/default/wacko.gif) Were those welded or threaded? (IMG:style_emoticons/default/laugh.gif) Mike |
Mueller |
Apr 21 2004, 10:59 AM
oh yea...thanks to Tim as well (IMG:style_emoticons/default/smilie_pokal.gif)
that was indeed the correct spec, I just was not too sure due to the description and from the SAMA spec that Ken mentioned that the PCA wants rims to be built to. I just wish the information from SAE was cheaper, tons of stuff I'd like to download and read...... |
davep |
Apr 21 2004, 11:13 AM
914 Historian Group: Benefactors Posts: 5,207 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
QUOTE(Mueller @ Apr 21 2004, 08:59 AM) I just wish the information from SAE was cheaper, tons of stuff I'd like to download and read...... I feel the same way about getting the information. Couldn't get my boss to stump up for the costs. I was looking for ratings on automotive wires: current vs gage & strand counts, also fuse ratings vs circuit current. |
Lo-Fi Version | Time is now: 20th October 2024 - 06:56 AM |
