jeff9146 |
Newbie ![]() Group: Members Posts: 13 Joined: 25-October 10 From: France Member No.: 12,313 Region Association: None ![]() |
Hello everybody !
First of all, as I am a new menber, let me introduce myself, After restoring a 911SC, I bought a 914/4 . After buying, I discover major rust on the body. By chance I know a very clever body worker, and the job is on the way. Last summer, I had the opportunity to buy a 914/, second hand, in very good condition, so I bought it. At the moment, I am having a look at the front brake system, and there is something I do not understad very well. On my PET, the référence for the rotors is 477.405.083A (20mm thick, the same as for the SC) And on the rotors I have on the car, the engraved reference is 901.351.041.16 , 18,5mm thick (my PET says they are for 911 T/E/S) with calipers ATE 245 My questions are : - will the calipers be OK with the rotors 477.405.083A ? - what are the differences between the M,S,A calipers? Many thanks for your answers, I apologize for my poor english, but you know, I am a frenchie... (IMG:style_emoticons/default/smile.gif) Jeff |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
To answer your questions: Yes, the 20mm rotor will be fine and is what everyone sells for that application. M-Calipers: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.pmbperformance.citymax.com-1110-1288124925.1.jpg) * 48mm Pistons * Steel * Ribe M8 Fasteners (13mm nuts) * AP31 pad size (same as the early 914 front and 914-6 rear) * Side Fluid inlet * 3" mounting ear spacing * 7lbs 6oz without pads S-Caliper: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.pmbperformance.citymax.com-1110-1288124925.2.JPG) * 48mm Pistons * Aluminum * Early units are cast off the 908 caliper casting and are clear anodized. * Later units are a combination of the 910 style nose and 908 rear and are greenish in color due to the dichromate sealant. * AP45T pad size (same as the A-Caliper but the "T" stands for thicker) * Side Fluid inlet * 3.5" mounting ear spacing * 5lbs 6oz without pads A-Caliper: (IMG:http://www.914world.com/bbs2/uploads_offsite/www.pmbperformance.citymax.com-1110-1288124926.3.jpg) * 48mm Pistons * Steel * Ribe M9 Fasteners (14mm nuts but small R6 heads) * AP45 pad size (same as the S-Caliper but not as thick) * Fluid inlet on the bottom of the widows peak in the back * 3.5" mounting ear spacing * Heaviest caliper ever made for a Porsche at 9lbs 4oz without pads. Read: PIG in the unsprung weight category. Hope that helps. You're English is great! |
brp986s |
Member ![]() ![]() Group: Members Posts: 434 Joined: 27-September 07 From: los angeles Member No.: 8,167 ![]() |
Hope that helps. You're English is great! Unfortunately yours isn't. (IMG:style_emoticons/default/biggrin.gif) |
Gustl |
914 enthusiast & historian ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,537 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria ![]() ![]() |
jeff9146 |
Thanks a lot for your welcome, I do appréciate
And thanks so much to Eric for all the informations and the pictures. That's a great help ! I had a look at my calipers, and as the nuts are 13 mm Hex., they seem to be M version. I will check the distance between ears on tomorow, Jeff |
Eric_Shea |
QUOTE Unfortunately yours isn't. (IMG:style_emoticons/default/av-943.gif) correct. "Your" English is great. QUOTE I had a look at my calipers, and as the nuts are 13 mm Hex., they seem to be M version. I will check the distance between ears on tomorow, No need to check... 13mm = M-Calipers. They will be the 3" spacing. Stock for a 914-6. Happy to help. |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
Hope that helps. You're English is great! Unfortunately yours isn't. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/av-943.gif) |
Eric_Shea |
Your making fun of me... (IMG:style_emoticons/default/mad.gif)
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
your'snot would have been closer.
We don't make fun of you Eric .... you're quite capable of that yourself. In fact, I have always thought of you as about 2 cards short of a full dick. |
Lo-Fi Version | Time is now: 25th June 2024 - 08:30 PM |
