914momo |
Member ![]() ![]() Group: Members Posts: 154 Joined: 15-April 04 From: ORYGUN Member No.: 1,933 ![]() |
What will keep my engine cooler, the 911 style fan or stock setup? I really like the looks of the 911 style but am not sure..
machina |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,030 Joined: 21-June 03 From: Miami Beach, FL Member No.: 848 ![]() ![]() |
The DTM fan cools better than anything else and draws less power. The 911 fan and shrouds require alot of power to drive but are probably better at moving air than the stock fan, but you proably don't need that much cooling.
dr |
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
Keep it stock, the DTM might offer a bit better cooling, but fitting it would be a PITA. 911 style may look cool and works on a 911, but they suck on a /4. If you want it to look bling do a lot of paint and powder coat detail.
Put your money in the engine, not on it. (IMG:style_emoticons/default/smile.gif) |
cnavarro |
Cylinder Guru ![]() ![]() Group: Members Posts: 472 Joined: 30-December 02 From: Chicagoland! Member No.: 49 Region Association: None ![]() |
Why is your engine running hot? There might be an underlying problem causing these conditions and adding a big fan isn't necessarily the answer but rather a big band-aid.
Charles Navarro LN Engineering http://www.LNengineering.com Aircooled Precision Performance |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
The stock arrangement does an above average job of cooling- more even than any 911 system that I tested.
The DTM will fit a 914 with slight mods that I can do to it. On a certain F Production we went from a FAT 911 shroud to my DTM and the engine dropped 75 degrees immediately and is now the front runner in the region. Running that much cooler and losing less energy to mechanical drag freed up that much power. The DTM does weigh less, about 1/2 of the stock arrangement and is easier to get to certain parts of. design the engine to make less heat, and you'll be ahead of the game. My 2316 makes 181 BHP in my 914 with 10:1 CR and it runs as cool as my stock engine did!! |
machina |
QUOTE(Jake Raby @ Apr 22 2004, 09:06 AM) My 2316 makes 181 BHP in my 914 with 10:1 CR and it runs as cool as my stock engine did!! hey jake, do you run pump gas or race gas? dr |
Lo-Fi Version | Time is now: 26th June 2024 - 04:01 AM |
