Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
It's got a T1 engine with a cooling system that’s a cross between a T3 and a T4. The engine is cast different with the breather tower over the 2/4 web and the nose is cast more like a T4. 34 PICT carb, stock intake ends but the centre section is different. The entire cooling shroud is steel, even the fan housing. The heater boxes are almost stock but have extra long 's' shaped tubes on the ends. Everything does look factory, serial # CT131429
Jake or anyone ever seen one like it? Industrial engine? Euro or third world? Attached image(s) ![]() |
Mark Henry |
different angle
Mark Henry |
overhead
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
is it cis?
Mark Henry |
QUOTE(seanery @ Apr 22 2004, 07:42 AM) is it cis? stock beetle carb. |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,162 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
Mark Henry |
Lo-Fi Version | Time is now: 29th June 2024 - 04:25 AM |
