Type IV, When was it born? |
76-914 |
Dec 14 2010, 09:15 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,613 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
type47 |
Dec 14 2010, 09:28 AM
All I know is that it was the engine in a 1972 VW bus and I think made for the VW 411 and 412... Last application I know of is in an 83 Vanagon
Root_Werks |
Dec 14 2010, 09:36 AM
Village Idiot Group: Members Posts: 8,426 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
1969 1.6 T4 I believe.
jcd914 |
Dec 14 2010, 04:14 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
VW 411 was introduced in late 1968 as a 1969 Model with the 1.7L type 4 engine.
I have only heard of 1.7L, 1.8L and 2.0L type 4 engines from VW. 1971 or 72 the VW bus got the 1.7L. Jim |
type47 |
Dec 14 2010, 04:53 PM
'71 bus had a type I engine; '72 had type IV
Root_Werks |
Dec 14 2010, 05:01 PM
1.7 yes, sorry, don't know where I got 1.6 from?? (IMG:style_emoticons/default/blink.gif)
August 1968 Mass-production of the VW 411 was started. September 1968 A full prototype of a VW 411 Cabriolet was built by Karmann Coachbuilders of Osnabrück (code name: Model Hamburg; no EA-number is known although a Cabriolet option was styled as EA 237 in April 1967). When this car was presented at Wolfsburg, Volkswagen’s top management showed little interest. It was suggested that Karmann should develop a Cabriolet on the basis of the new two-door version of the Audi 100 instead. Karmann actually presented the car at the 1969 Frankfurt Motor Show (IAA) but it never made it into production. Karmann also presented Volkswagen with an alternative to the proposed VW 411 Coupé. In this case a full prototype was presented of a 3-door hatchback version of the VW Karmann-Ghia Coupé Type 14. This design, called Type 143 TC, laid the foundation for the later VWdB Karmann-Ghia Type 145 TC. August 1969 The VW 411(L)E including the Variant (Type 46) was introduced. Although some photographs of this car had been released the previous Summer, it was launched with the new 1,7 litre 59 kW/80 hp fuel-injected engine and the facelifted front end with double headlights which were also given to the two- and four-door VW 411 E/LE saloons. |
brant |
Dec 14 2010, 05:13 PM
914 Wizard Group: Members Posts: 11,739 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
I don't know what car it came from
but there are super Vee's running 1.6 type 4's I assumed they were from some car? (maybe they are de-bored?.... doesn't make sense) brant |
URY914 |
Dec 14 2010, 05:17 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 123,039 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
I thought the '73 was the first year of the TIV in the bus? They changed the body style in '73.
SirAndy |
Dec 14 2010, 05:18 PM
Resident German Group: Admin Posts: 41,815 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
but there are super Vee's running 1.6 type 4's I thought those were T1 motors? (IMG:style_emoticons/default/confused24.gif) |
URY914 |
Dec 14 2010, 05:25 PM
but there are super Vee's running 1.6 type 4's I thought those were T1 motors? (IMG:style_emoticons/default/confused24.gif) They started out as t-1's in FV. Then a new class was made for super vees with t-4s. |
agentblr |
Dec 14 2010, 05:31 PM
Member Group: Members Posts: 303 Joined: 23-January 04 From: Lee's Summit MO Member No.: 1,595 |
I always thought the Type 34 Ghia had a T4 motor (IMG:style_emoticons/default/huh.gif) Looks nothing like a T1 ? (IMG:style_emoticons/default/confused24.gif)
Attached thumbnail(s) Attached image(s) |
URY914 |
Dec 14 2010, 05:33 PM
That is a T-III.
Really a T-1 with the fan mounted on the front not on the top. |
URY914 |
Dec 14 2010, 05:34 PM
T-III.....
underthetire |
Dec 14 2010, 06:05 PM
914 Guru Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
I thought the '73 was the first year of the TIV in the bus? They changed the body style in '73. I know 72 was a T-4, without an access hatch to get to the carbs (IMG:style_emoticons/default/headbang.gif) And not sure of any body change then, just different bumpers. |
Cap'n Krusty |
Dec 14 2010, 07:01 PM
'72 T2s had the 1.7L T4 engine, and the same bumpers and front turn signals as the 68-71 versions. No engine overhead access hatch. Early model tail lights. Solid panel across the back below the engine lid. First year for the engine mounts over the bell housing, giving 5 mounting points instead of 3. '73s had the same engine, but with the hatch, a paper element air cleaner, and a smog pump. The front turn signals were moved up high, and the bumpers became bigger and more simple. There was a large crush section behind the front bumper. No wraparound step on either end. Large tail lights in which the turn signal function was separated from the brake light bulb, and the back-up light was integrated. Busses had carbs through the '74 model year.
The T4 engine, as others have said, came to the market in 1969, installed in the 411, and later, the 412 model. The T4s had a gasoline heater, and nearly all of them sold in the US were equipped with auto transmissions. Just for fun, VW put the battery under the driver's seat and the master cylinder was bolted to the steering column ................... Unlike the T2s, all the US T4s were EFI. The 1.8 with L-jet appeared in '74. The Cap'n |
KELTY360 |
Dec 14 2010, 07:02 PM
914 Neferati Group: Members Posts: 5,081 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
I thought the '73 was the first year of the TIV in the bus? They changed the body style in '73. I know 72 was a T-4, without an access hatch to get to the carbs (IMG:style_emoticons/default/headbang.gif) And not sure of any body change then, just different bumpers. (IMG:style_emoticons/default/agree.gif) |
r_towle |
Dec 14 2010, 07:10 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Just for fun, VW put the battery under the driver's seat and the master cylinder was bolted to the steering column The Cap'n I tell my son this is Hanz and Franz the two brothers who have roamsed through many german car manufacturing plants and contributed evil design ideas just to piss off people. the later creations ,as Hanz and Franz got older, were specialized on the interiors of Audi's and then once they mastered the art of inventing single use fasteners they moved to the VW division to create the completely breakable interior....the best known versions were in the early passats. Best knows throughout automotive history for the overall manufacturing process of building a mercedes by hanging the fresh air/heater fan in mid air and then building a car around it. Of course the fan has a very short lifespan. Rich |
JFJ914 |
Dec 14 2010, 07:30 PM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
jcd914 |
Dec 14 2010, 07:57 PM
I don't know what car it came from but there are super Vee's running 1.6 type 4's I assumed they were from some car? (maybe they are de-bored?.... doesn't make sense) brant As I recall, they were 1600 cc stationary industrial engines, not car engines. From Wikipedia: "Initially the series allowed 1600cc air-cooled engines of either type 3 (as used in the Beetle) or type 4 (as used in the VW-Porsche 914 sports car), however at a late stage VW had a change of heart and decided that the type 4 engines would be a better option. The type 4 engine is without doubt a better engine. However, this motor was never produced in a 1600cc version so VW decided to produce a "special" 1600cc version through their industrial engines division (the 127V unit), with smaller pistons and barrels, which reduced the capacity to 1600cc." |
Cap'n Krusty |
Dec 14 2010, 08:11 PM
Just for fun, VW put the battery under the driver's seat and the master cylinder was bolted to the steering column The Cap'n I tell my son this is Hanz and Franz the two brothers who have roamsed through many german car manufacturing plants and contributed evil design ideas just to piss off people. the later creations ,as Hanz and Franz got older, were specialized on the interiors of Audi's and then once they mastered the art of inventing single use fasteners they moved to the VW division to create the completely breakable interior....the best known versions were in the early passats. Best knows throughout automotive history for the overall manufacturing process of building a mercedes by hanging the fresh air/heater fan in mid air and then building a car around it. Of course the fan has a very short lifespan. Rich Audi aficionados know those guys as "Team Doorhandle". The Cap'n |
Lo-Fi Version | Time is now: 27th September 2024 - 09:20 PM |
