> Any body doing this ? 914 w/Hayabusa motor . ?, pro's con's , support or poke holes. Wtb : your 2 cents
thelogo
post Dec 16 2010, 02:10 PM
Group: Retired Members
http://cgi.ebay.com/ebaymotors/09-SUZUKI-H...ht_10790wt_1167
Just wondering would this engine be viable for a conversion .
It makes good power . small , water cooled . f. i . wet sump .
Is it as simple as toss the type 4 . clutch adapter kit and wiring
or is it much more complex .
The radiator is Tiny . smaller then most oil coolers ? so It would not need front mounted huge heat exchanger ?
for some reason it runs right next to the header pipe ???
Please give me your thought's .
pro's
con's
cost s
ability to go back to type 4 motor if desired ?
hey o .
http://www.youtube.com/watch?v=gbBfDOPeZ2g
(IMG:style_emoticons/default/flag.gif) Much respect and thank you to BOB FELLER > for being a positive role model (IMG:style_emoticons/default/flag.gif)
underthetire
post Dec 16 2010, 02:16 PM
Plenty of busa conversions, havn't seen one in a 914. Initial torque might be an issue.
See
http://www.youtube.com/watch?v=IlJ_Idds3Ts...feature=related
GeorgeRud
post Dec 16 2010, 02:35 PM
Naw, save these motors for conversions into Smart Cars and old school Minis, they really make those cars fly!
I wondor how one would work in a LoCost (Lotus 7 homemade replica).
post Dec 16 2010, 02:38 PM
Resident German
QUOTE(thelogo @ Dec 16 2010, 12:10 PM) *
Do a search ... (IMG:style_emoticons/default/biggrin.gif)
It's been discussed before. In length ... (IMG:style_emoticons/default/shades.gif)
RJMII
post Dec 16 2010, 02:41 PM
Jim McIntosh
I've been eyeballing these units for sometime now. My plan is to build a sandrail (the Baracuda by the EDGE) with a 'busa power plant.
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.sandbullet.com-8112-1292532070.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/www.sandbullet.com-8112-1292532072.2.jpg)
Rear dif with reverse. (IMG:style_emoticons/default/smile.gif)
new rear drive system can be done with or with out
reverse but also includes the following features:
Chain drive with rear sprocket as large as 72 tooth
Inboard or out board brakes
Limited slip differential or solid axle
930 CV output
Adjust chain tension on chain roller needed
(http://www.sandbullet.com)
RJMII
post Dec 16 2010, 02:43 PM
Jim McIntosh
my $.02 would be: just do it. stop hashing it out and do it. If you do it right, you will prove one way or the other and you will know what broke in the process. The mythbusters would be proud.
Porcharu
post Dec 16 2010, 04:26 PM
I want the V8 version like the one Radical sells for $$$$. Someone in the midwest used to make the crankcase assembly's that you bolted 2 sets of cylinders and heads onto.
2.6 liters of screaming little V8 would be a blast in a 914.
Mike Bellis
post Dec 16 2010, 04:30 PM
Resident Electrician
www.h1v8.com
(IMG:style_emoticons/default/aktion035.gif)
michaelt55
post Dec 16 2010, 04:43 PM
Graduate of Life's experiences
too rich for my blood...as said on commercials..I could of had a V8...
thelogo
post Dec 16 2010, 05:17 PM
QUOTE(michaelt55 @ Dec 16 2010, 02:43 PM) *
I agree that h1 v8 / ocho is too much $
the 4 cyc busa on ebay is pushing it at . 4.5 k
I think i'll start letting budget navigate for a moment
and see what alternative motors that yields / ?
but for 27 k i'd have to go / Ford COsworth Subaru engine ?
linky :
http://www.cosworthusa.com/store/pc/viewCa...sp?idCategory=2
and anybody know if you could get 400 horse from a por.6
naturally asp . that would rev to 10 k .
you'd be thinking expensive motor every time you blew it up !!!
I assume busa engine hits 15 k easily ?
Mike Bellis
post Dec 16 2010, 05:35 PM
You can always go the route I am. Turbo Rotary. You can get 500hp easy and it will rev to 10K. $4-5K will get you a good used engine to start with along with all the parts to install it.
J P Stein
post Dec 16 2010, 05:53 PM
Irrelevant old fart
QUOTE(kg6dxn @ Dec 16 2010, 03:35 PM) *
Easy? You can show us how easy after you have it up & runnin'.
The only "easy" part is talking about it.
Britain Smith
post Dec 16 2010, 06:54 PM
Nano Member
One issue is that this motor is not legel to put into a car for SCCA. If you do it then you will be put into AMod.
rick 918-S
post Dec 16 2010, 06:59 PM
Hey nice rack! -Celette
QUOTE(SirAndy @ Dec 16 2010, 02:38 PM) *
(IMG:style_emoticons/default/agree.gif) But I think I remember we discussed lots of hp but not enough torque and puny clutch
Andyrew
post Dec 16 2010, 07:05 PM
Spooling.... Please wait
There are quite a few motorcycle engine'd Lotus 7 replica's/ one offs.
oldschool
post Dec 16 2010, 07:18 PM
how about this ......Attached Image
Mike Bellis
post Dec 16 2010, 07:37 PM
QUOTE(J P Stein @ Dec 16 2010, 03:53 PM) *
Here's a picture of one for the Non beleivers... Courtesy of Rotary14
Or if you want super high HP and a custom install. Go this route... T.M.C. (Too Much Custom) (IMG:style_emoticons/default/barf.gif)
tomeric914
post Dec 16 2010, 07:43 PM
One Lap of America in a 914!
QUOTE(kg6dxn @ Dec 16 2010, 08:37 PM) *
This is an advantage how? (IMG:style_emoticons/default/slap.gif)
RJMII
post Dec 16 2010, 07:45 PM
Jim McIntosh
QUOTE(oldschool @ Dec 16 2010, 06:18 PM) *
That would be cool.
It would lose a few hundred pounds from the sheet metal, the transaxle, and cooling tins. The trailing arms and brakes would be swapped out for something a little lighter.
Using fiberglass fenders and hood up front along with a small fuel cell in the spare tire hole would further the diet plan. Then get rid of all the heating stuff (who would drive it in the cold weather? )
Adding a GT headlight kit would get rid of the pop up motor weight.
I bet the car could be made light enough to go for a 'busa engine.
raw1298
post Dec 16 2010, 08:07 PM
(IMG:style_emoticons/default/happy11.gif) My father in law has a busa, still in the bike, I wonder if he would notice it missing. (IMG:style_emoticons/default/happy11.gif) The T-Rex is a cool cart!
- Lo-Fi Version Time is now: 17th April 2025 - 08:42 PM
