> Valve cover gasket glue, what do you use
Krieger
post Dec 18 2010, 08:54 PM
I went in asking for Gask-a-cinch and the oldtimer at my favorite flaps told me this is the stuff to have: a tube of 3M Super Weatherstrip and Gasket Adhesive. Any experience with this stuff? What do you fellas use?
Jake Raby
post Dec 18 2010, 09:01 PM
Engine Surgeon
The 3m works well.. Just use it on the valve cover side, then grease the side that fits to the head.
I didn't change the valve cover gaskets on my 912E engine over 160K miles using this method.
charliew
post Dec 18 2010, 09:14 PM
I always used the 3m but it is a job putting on new gaskets and cleaning the 3m off. What about using a silicon adhesive on the valvecover side? I would think it would clean off a lot easier.
quadracerx
post Dec 18 2010, 09:15 PM
Yea it works REALLY GOOD....used to call it "Yellow Gorilla Snot" be careful with it..it tends to get everywhere you dont want it to....and its kinda like welds stuff together...LMAO
Good Luck....
Steve
Krieger
post Dec 18 2010, 09:18 PM
QUOTE(Jake Raby @ Dec 18 2010, 07:01 PM) *
Thanks Jake. I don't think I've changed out my gaskets in 8-9 years. 10k miles in that time. Its time to check the valves and I figured while I was in there maybe its time. I have 0 leaks. What do you think Jake do it or not? I probably won't get in there for another 2 years to check vavle lash.
mrbubblehead
post Dec 18 2010, 09:23 PM
Twodollardoug
i use gask-a-cinch on the cover side. dry on the head side.
Krieger
post Dec 18 2010, 09:26 PM
QUOTE(mrbubblehead @ Dec 18 2010, 07:23 PM) *
I could not find the gask a cinch. probably illegal in california.
sww914
post Dec 18 2010, 09:37 PM
Contact cement on the cover side, dry on the head side. They last a long time.
Jake Raby
post Dec 18 2010, 10:15 PM
Engine Surgeon
I didn't have to change the gaskets in 8 years/ 160,000 miles.
If its not leaking, then don't worry about sealing them.
mrbubblehead
post Dec 18 2010, 10:21 PM
Twodollardoug
QUOTE(Krieger @ Dec 18 2010, 07:26 PM) *
i live in california, maybe try napa. i think kragens carries it. i coat one side of the gasket with it and then the valve cover. let it dry for about 5 minutes and stick them together. you need to be accurate when you join them together because you only get one shot at it. once the gasket touches the valve cover theres no repositioning it. the reason i like gask-a-cinch over the 3m is when its time for new gaskets they come of with a putty knife with minimal prep. usually a wire brush will do. the 3m takes alot of work to get off. IMO. not near as messy also.
VaccaRabite
post Dec 19 2010, 09:20 AM
En Garde!
I use the 3M stuff too. A very thin smear on the valve cover side. Almost never have to swap out gaskets.
Zach
StratPlayer
post Dec 19 2010, 11:10 AM
StratPlayer
http://www.kedo.com/base_com/21053.html
davesprinkle
post Dec 19 2010, 11:16 AM
We're talking about the cork seals, right? Why do you use sealer? I've just greased both sides with no leaks.
Bartlett 914
post Dec 19 2010, 12:59 PM
QUOTE(davesprinkle @ Dec 19 2010, 12:16 PM) *
So the gasket will stay in place better when you install the valve cover. By not sealing the engine side, the gasket can slide a little against the head without moving the gasket out of place.
NC_Colfax
post Dec 19 2010, 07:38 PM
I used a couple of drops of super glue. Worked very well for me under the car.
Pat Garvey
post Dec 19 2010, 07:43 PM
Do I or don't I...........?
Yo!
VaccaRabite
post Dec 20 2010, 06:52 AM
En Garde!
QUOTE(Bartlett 914 @ Dec 19 2010, 01:59 PM) *
With mine, I bought a lot of the cork gaskets at once one day, and they are kinda warped. If I put the gasket on w/o sealant on the cover, it will not lay flat and I get a huge leak. A super thin smear of sealant to glue it to the valve cover, and it is good to go for a LONG time.
If grease is working for you, great! Will save you time cleaning up the sealant when the gasket has to finally be retired.
Zach
stugray
post Dec 20 2010, 07:07 AM
I will probably get flamed for this, but here is what I did on my ghia & previous 914:
I used blue RTV to glue the gasket into the valve cover, put it in place and "slightly" clamped it in place. This guarantees it drys flat.
Once that was dry I put a very thin film of RTV on the head side and let it dry.
They never leaked again after that and lasted for years.
Stu
VaccaRabite
post Dec 20 2010, 08:02 AM
En Garde!
But, how did you check your valves?
Zach
stugray
post Dec 20 2010, 09:08 AM
The RTV was allowed to dry before replacing the covers, so they went on & off with no trouble.
It just made the cork gasket more "silicone like".
Stu
- Lo-Fi Version Time is now: 22nd December 2024 - 05:43 AM
