HP gains |
HP gains |
matteyp |
Dec 25 2010, 07:13 PM
Nothing a little JB Weld can't fix... Group: Members Posts: 263 Joined: 8-June 09 From: WA Member No.: 10,450 Region Association: Pacific Northwest |
Does anyone know if they make jug kits for the 1.7? If so what hp and performance gains can be expected? Are there any other cheap performance mods for the 1.7? Thanks for the help guys.
jetboy |
Dec 25 2010, 07:34 PM
914 Uber Noob Group: Members Posts: 205 Joined: 16-September 05 From: Riverside, CA Member No.: 4,810 Region Association: Southern California |
ha ha, you said cheap. giggle.
matteyp |
Dec 25 2010, 07:54 PM
Wow that helps lol
RJMII |
Dec 25 2010, 08:58 PM
Jim McIntosh Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None |
define "cheap"?
I wanted more HP; so I put some obnoxious setup in my car that requires lots of tubing and ways to keep the air and fluids cool... as to your question about jugs; yes. There are 96mm pistons and jugs out there for the 1.7 that increase volume to 1911cc displacement. There are two different versions of jugs though, the kind that require the heads to be fly cut, and the kind that don't. |
tradisrad |
Dec 25 2010, 10:05 PM
Senior Member Group: Members Posts: 985 Joined: 11-September 06 From: San Mateo, CA Member No.: 6,815 Region Association: Northern California |
you may find it less expensive to find a decent running 2.0 and install that.
type47 |
Dec 26 2010, 07:33 AM
If your upgrade wants are guided by a desire for "cheap", then make your engine a good running one by adjusting the valves and doing a tune-up and making sure the fuel injection system is optimum. Quests for "more power" are funded by cubic dollars.
EdwardBlume |
Dec 26 2010, 07:42 AM
The cheapest way to boost your ride is to take weight out of the car... get a sawzall off CL and go nuts...
Seriously, these are old motors with old technology so not much is gained vs what you pay or do to get there. This might sound "crazy" but regardless of power, these sleds get more exciting to me when they have a nice balance of suspension upgrades... like 140 lb springs, a larger swaybar, and tighter torsion bars... |
orange914 |
Dec 26 2010, 05:09 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
any noticable gains over stock reality:
$100 per 1H.P. like has been said though, get it tuned, running great and enjoy. |
Al Meredith |
Dec 26 2010, 05:13 PM
Senior Member Group: Members Posts: 969 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
I have a set of 96 MM P/C for a 1.7 head. they tend to be a little thin where they fit into the head. I,ve never heard of a problem though. In addition to going to 1911 CC they are flat top pistons instead of the dome tops . CR should be a little lower. Then again the larger bore will raise CR probably=. If you want them , let me know AL
jeff |
Dec 26 2010, 05:25 PM
Member Group: Members Posts: 253 Joined: 17-January 04 From: thousand oaks,ca Member No.: 1,570 |
http://www.lnengineering.com/type4.html I think the least expensive way to go really fast is to buy a used modern sport bike like a GSXR ,One bad mistake and it's easy to pat the ultimate price though..
Tom |
Dec 26 2010, 05:41 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Matteyp,
First, ask yourself why you want more HP. These cars aren't drag racers. It is about carrying speed thru the corner and accelerating to the next. If that is what you are looking for, get the suspension working best you can, get brakes working great, put some good tires on, then get some seat time driving the car. If you want a little more acceleration without modifing the engine, you could go down in tire size to like 50's or so and get a little extra grunt at the expense of gas mileage and engine wear. That 1.7 will give a lot of thrills. My first 914 has a 1.7 and it was a blast in the twisties. I had f/g flares and 235's on the rear with 215's on the front and was running 60"s so I had a little extra grunt and the tires made the car stick in the corners very good. My buddy's 1970 "6" would eat me up on the straights, but my wider and lower aspect tires would make up the ground in the corners. Tom |
MassTeener |
Dec 27 2010, 10:07 PM
Newbie Group: Members Posts: 27 Joined: 25-December 10 From: Mass Member No.: 12,519 Region Association: North East States |
All good suggestions and questions you should be asking yourself...
Research, then do a little more. I have a 1911 with one of Dema's cam's and heads from Bugpatch. Fun little motor that is very responsive. That said, if the rest of the package isn't up to par, ie suspension,brakes, alignment,et, your car will still be leaving alot of the fun factor behind. And most important, do you like to wrench? (IMG:style_emoticons/default/beerchug.gif) |
stewteral |
Dec 27 2010, 10:28 PM
Old Member Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
Does anyone know if they make jug kits for the 1.7? If so what hp and performance gains can be expected? Are there any other cheap performance mods for the 1.7? Thanks for the help guys. HI Matteyp, I'm just finishing up a complete engine rebuild of my 1.7 L and have installed the 1914cc, 96mm Big Bore kit from AA Performance. This alone should be good for 10-15 HP and a good slug of torque. I would look at tweaking the F.I a bit richer. if that is all you do. For my engine I gone all the way: Big Bores, mild cam, Duel-throat Webers, $200 main bearings from AutoAtlanta, flycutting the heads to 1800 cc specs to fit the new bores, replace all guides and valve job. Shucks, for a little old VW engine, it has cost me $1000! I guess the real message is that HP isn't cheap. A machine shop I went to as a kid had a sign on the back wall: "Speed costs $$, How fast do you want to go?" Sorry, there's no cheap short-cuts. Best, Terry |
Eric_Shea |
Dec 27 2010, 11:03 PM
PMB Performance Group: Admin Posts: 19,289 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
QUOTE any noticable gains over stock reality: $100 per 1H.P. QUOTE should be good for 10-15 HP and a good slug of torque QUOTE for a little old VW engine, it has cost me $1000! So now you know why Chris "giggled" when you said cheap. The $100 per hp figure seems to be spot on. Find a 2056 and have fun, otherwise; drive the piss out of your 1.7 (if there's any left in there) and do the suspension mods that some of these guys have mentioned: Nice shocks New Bushings Sway-Bar for sure Killer tires and Awesome brake pads (IMG:style_emoticons/default/wink.gif) |
JRust |
Dec 27 2010, 11:19 PM
914 Guru Group: Members Posts: 6,313 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Does anyone know if they make jug kits for the 1.7? If so what hp and performance gains can be expected? Are there any other cheap performance mods for the 1.7? Thanks for the help guys. There is a rebuilt 1911 in the classifieds cheap ($500). It's in the bay area but you aren't likely to beat that. Even driving down to pick it up it's worth it for your car. |
RJMII |
Dec 28 2010, 01:52 PM
QUOTE Find a 2056 and have fun, otherwise; drive the piss out of your 1.7 (if there's any left in there) and do the suspension mods that some of these guys have mentioned: Nice shocks New Bushings Sway-Bar for sure Killer tires and Awesome brake pads (IMG:style_emoticons/default/agree.gif) http://www.pmbperformance.com is where to get that stuff. It'll change your experience through corners and canyons enough to where you'll forget about 0-60 times. well, almost forget. |
BuddyV |
Dec 28 2010, 02:11 PM
Robert Group: Members Posts: 564 Joined: 8-April 05 From: Santa Rosa, CA Member No.: 3,898 Region Association: Northern California |
MatteyP -
I'm the guy selling the 1911 in the classifieds. I really liked the 1911 in my 914. Not tremendous power, but well-balanced for this car design/weight. Never did I feel reluctant to smash my right foot down coming out of a corner... just the right amount of power, I thought. From my experience, make sure whatever you build will be reliable. DRIVING these cars is what it's all about..... nothing fun about seeing the car parked while in the process of a "weekend fix" that lasts several months. Cheers and happy driving! |
RJMII |
Dec 28 2010, 05:30 PM
A 1911 for $500? really? That's a good deal. (IMG:style_emoticons/default/smile.gif) What pistons did you put in it? Were the heads flycut? This goes along with what MatteyP asked about, the bigger jugs... all the work done for a little more than the cost of the pistons and jugs and machine work.
Root_Werks |
Dec 29 2010, 10:12 AM
Village Idiot Group: Members Posts: 8,525 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
Mattey,
You've got a ton of local guys to look at for examples. I can't remember if your 914 is FI or carb'd? I like 1.7's. Bring your 914 to a local teener event and then ride around in a stock 2.0FI, a carb'd 2.0, maybe a 1911, 1.8 and so on. Just slipping in a 1911 P/C kit won't really yield much for the money spent. I have seen some pretty crazy 1911's with proper cams, head work, tuned carbs. But in the end, they should have started with a GA or GC 2.0. You're best bang for the buck is probably to find a good stock 2.0FI and just do the conversion. It'll add value to your 914 as well. (IMG:style_emoticons/default/driving.gif) |
sixnotfour |
Dec 29 2010, 10:37 AM
914 Wizard Group: Members Posts: 10,698 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
QUOTE You're best bang for the buck is probably to find a good stock 2.0FI and just do the conversion. It'll add value to your 914 as well. The 2,0 longer stroke is makes them bettter imho. The 1.7 engine in your car will need more than PC's. shameless plug; I have a 1973 2.0 complete. I dont know if it ran or not no keys and the body went to minnesota and the motor has been in storage since. maybe good - maybe bad ,But it is a better start than the motor in your car. The big plus is your car stays driving untill your ready to swap it out. The price wont be bad as I gave Rich the 1.7 with injection. |
Lo-Fi Version | Time is now: 4th January 2025 - 09:56 PM |
