steeks |
Newbie ![]() Group: Members Posts: 36 Joined: 25-October 10 From: Prescott Valley, Arizona Member No.: 12,310 Region Association: None ![]() |
I was wondering if anyone has replaced the old torsion bar lifting system on the rear trunk lid with modern hydraulic lifters, seems like a pretty simple deal, Pictures anyone?? Thanks.
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,179 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
Rod |
Senior Member ![]() ![]() ![]() Group: Members Posts: 616 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England ![]() |
Fitted the camp kit and it works brilliantly - you do get used to holding onto the engine lid as you open it - as they have a lot of power and can push it up pretty fast!!
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
All my cars have been fitted with the gas shocks ... cut those MFer torsion bars out and never looked back.
JoeSharp |
In Irvine, Ca. May 15-18 ![]() ![]() ![]() ![]() Group: Members Posts: 3,947 Joined: 9-July 03 From: DeLand, Florida Member No.: 898 Region Association: South East States ![]() |
Be careful as they are under alot of tension. They do go BANG!!!
montoya 73 2.0 |
Lack of consideration to others, and Selfish! ![]() ![]() ![]() Group: Members Posts: 1,791 Joined: 27-October 04 From: Paso Robles, Ca. Member No.: 3,016 Region Association: Central California ![]() |
I have the Camp914 kit on mine, they work great!
TC 914-8 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 812 Joined: 23-May 08 From: Sequim, WA Member No.: 9,090 Region Association: Pacific Northwest ![]() ![]() |
I was just thinking of converting to the shocks the other day. Do they get in the way when storing the top ?
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,623 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
They do not interfere with the top. I had to remove my torsion bars anyway to clear the fuel injection on my 3.2 motor anyway. The down side the shocks ware out, but are easily found at your local auto parts store.
raw1298 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 616 Joined: 9-March 09 From: Rocklin,Ca. Member No.: 10,148 Region Association: Northern California ![]() |
Are the shocks ok to use with a fiberglass decklid?
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,712 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
SLITS |
davesprinkle |
Senior Member ![]() ![]() ![]() Group: Members Posts: 720 Joined: 13-October 04 From: Berkeley, CA Member No.: 2,943 Region Association: None ![]() ![]() |
I'm going to disagree with the conventional wisdom here. The torsion springs work great and they never fail. If you install the shocks, you'll need to cut the sheet metal on your trunk.
The factory got it right with the design of the torsion springs. Don't replace them. |
Krieger |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,734 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None ![]() ![]() |
montoya 73 2.0 |
The factory got it right with the design of the torsion springs. Don't replace them. Except when the trunk hinges tear off the inner fenderwell. Which seems to happen to almost half the cars out there. (IMG:style_emoticons/default/chair.gif) Thats exactly what happened to me and the springs were bent from someone prying on them?! |
VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,479 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() |
I have struts for the front and rear trunk. I like it WAY more then the springs.
Zach |
jaxdream |
Senior Member ![]() ![]() ![]() Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States ![]() |
VaccaRabite |
I have struts for the front and rear trunk. I like it WAY more then the springs. Zach Can you share the part number or the vehicle that they were originaly intended for , front trunk o'course is what I'm refering to ?? T I A ... Jack / Jaxdream I can't. I bought it as a kit from Camp914 a few years ago. but I don't think it would be hard to source the materials to DIY it. Zach |
McMark |
PET PEEVE ALERT
You want an easy install? Buy the kit someone else invested time and energy into developing. Consider the extra cost a 'thank-you' for that person doing all the work for you. You want something cheap? Do the research yourself and build your own parts. (IMG:style_emoticons/default/stick.gif) Okay, I'm done. |
jaxdream |
Thanks , Zach , I'll check the site out. Wasn't sure if they did fronts . I know they advertised rears. Thanks again for the reply . (IMG:style_emoticons/default/piratenanner.gif)
Jack / Jaxdream |
Lo-Fi Version | Time is now: 1st July 2024 - 05:24 AM |
