scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
I have to make a custom bumper for a car. I am familiar with the mold process but what I do not know is what type of expandable foam I should buy. I am planning to make a wooden box ( form) to pour the foam in, then attatch it to the car and start cutting and sanding to get the desired shape. What I need is something that will expand and still be closed cell enough to handle cutting, sanding and shaping, then can handle bondo being applied to get that oh so smooth ready to be painted, finished buck. (IMG:style_emoticons/default/wacko.gif)
underthetire |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California ![]() |
Tap plastics used to sell a resin foam, it was pretty tough stuff, but a little on the heavy side. My project cam out like sh*t but thats just me.
Rod |
Senior Member ![]() ![]() ![]() Group: Members Posts: 616 Joined: 1-January 08 From: Farnham UK Member No.: 8,526 Region Association: England ![]() |
Use polyurethane two-part foam, The foam from diy shops is rubbish for your purpose - it leaves big holes as it expands.
jd74914 |
Its alive ![]() ![]() ![]() ![]() Group: Members Posts: 4,782 Joined: 16-February 04 From: CT Member No.: 1,659 Region Association: North East States ![]() |
I don't have much experience, but if you want to pour foam, use a 2lb poly foam. To let it cure nicely and keep from being super porous, you probably will want to pour in multiple stages. It might be easier to used closed cell insulation-type foam from Home Depot or Lowes (the blue is typically used), and form with a hot knife and then belt sander. |
iamchappy |
It all happens so fast! ![]() ![]() ![]() ![]() Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest ![]() ![]() |
Have you considered using Styrofoam and shaping it instead of a using a mold.
I have done things this way as well as it is the standard for making fiberglass surf and sailboards. Just throwing it out there.... |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,302 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
Try looking at some of the projects on here.....
http://www.fiberglassforums.com/ I'm a member to this forum and they have some good folks that can help you out. |
RJMII |
Jim McIntosh ![]() ![]() ![]() ![]() Group: Members Posts: 3,125 Joined: 11-September 07 From: Sandy, Utah Member No.: 8,112 Region Association: None ![]() |
This place seems to have a lot of information. I did a bunch of reading there a few years ago, but haven't been able to put anything into practice yet.
http://www.fiberlay.com/ edit: The expandable foam link is on the left, couldn't get a good link directly to where I was trying to show you. |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
Order some surf board blanks (IMG:style_emoticons/default/aktion035.gif)
There's surf shops all over on the Left Coast (IMG:style_emoticons/default/smoke.gif) |
URY914 |
I see the pink insulation boards that you can get at Home Depot being used a lot. I plan on using them when I make a new piece for my car.
stepuptotheMike |
medium pimpin ![]() ![]() ![]() Group: Members Posts: 565 Joined: 4-September 06 From: Charlotte, NC Member No.: 6,769 Region Association: South East States ![]() |
One of the shows I saw on TV used sheets of florist foam...they laminated sheets of it together with gorilla glue to get the thickness needed and then shaved it down to shape. They were making fender flares.
Mike |
URY914 |
The spray on foam seems to be used also...
Before ![]() After ![]() |
r_towle |
Scotty,
Use the simple spray foam and cover it entirely with plaster or paris. the plaster will not degrade with the fiberglass epoxy. Use the plaster like bondo. Rich |
mepstein |
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,334 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region ![]() ![]() |
comes in 914 colors
Attached image(s) ![]() |
PlaysWithCars |
Senior Member ![]() ![]() ![]() Group: Members Posts: 528 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest ![]() ![]() |
Use the pink stuff from Home Depot. You can rough the shape in with a course wood file, then finish sand to shape w/ 80 grit sandpaper. But, you need to cover it with something before laying fiberglass over it, the resin will melt the foam.
I just used it over the holiday to make a mold for my "GT" seat project. Worked great and now I have two 914 seat shells w/ extended bolsters. (IMG:style_emoticons/default/cheer.gif) Next step is to learn how to do upholstery. ![]() ![]() ![]() |
Dr Evil |
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region ![]() ![]() |
I have used the spray foam. Cheap and easy, oh ya (IMG:style_emoticons/default/sheeplove.gif)
scotty b |
The sheets and particularly spray foam just isn;t going to cut it. I'm talking about a whole front bumper. That stuff may be great for a small project or a home doer, butI have to keep this within a reasonable budget. Surfboard blanks crossed my mind but the amount I would need would be $$$$ plus shipping got to be even more $$$$$$. I am looking for expandables because they are smaller to ship, they will fill a large box fairly quick and easily, and it looks so cool when it starts to grow (IMG:style_emoticons/default/smoke.gif) I'll check out the sites Paul and Jim posted (IMG:style_emoticons/default/smile.gif) Mike, I hadn;t thought about florist foam, I know I can get that locally in large chunks but will it hold up to the ibeglass resin ? A lot of foams will disolve. I will be making a female mold off of the buck, but will keep the buck just in case. If this turns out well I am going to try and sell them. Under wraps for now so dont ax (IMG:style_emoticons/default/shades.gif) not for a 914 though, but it is in la familia (IMG:style_emoticons/default/smile.gif)
Dr Evil |
URY914 |
Yes the green foam used by the flower folks will not get eaten by the resin. I just used some today. (IMG:style_emoticons/default/biggrin.gif)
Phoenix-MN |
Senior Member ![]() ![]() ![]() Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 ![]() |
This place has all the "glassing" supplies you'll ever need.
http://www.cstsales.com/ I used thier Rohacell foam when I had to modify my front bumper. The stuff is a little spendy but works very well. Paul |
stepuptotheMike |
(IMG:style_emoticons/default/sunglasses.gif)--><div class='quotetop'>QUOTE(scotty b @ Jan 5 2011, 10:08 PM)
![]() The sheets and particularly spray foam just isn;t going to cut it. I'm talking about a whole front bumper. That stuff may be great for a small project or a home doer, butI have to keep this within a reasonable budget. Surfboard blanks crossed my mind but the amount I would need would be $$$$ plus shipping got to be even more $$$$$$. I am looking for expandables because they are smaller to ship, they will fill a large box fairly quick and easily, and it looks so cool when it starts to grow (IMG:style_emoticons/default/smoke.gif) I'll check out the sites Paul and Jim posted (IMG:style_emoticons/default/smile.gif) Mike, I hadn;t thought about florist foam, I know I can get that locally in large chunks but will it hold up to the ibeglass resin ? A lot of foams will disolve. I will be making a female mold off of the buck, but will keep the buck just in case. If this turns out well I am going to try and sell them. Under wraps for now so dont ax (IMG:style_emoticons/default/shades.gif) not for a 914 though, but it is in la familia (IMG:style_emoticons/default/smile.gif) [/quote] Worse comes to worse.... cover it in aluminum foil. Then glass over it to make your mold. I've never personally used it... but that's how they did it on the TV episode.... I think it was the show Musclecar on SpikeTV. Mike |
Lo-Fi Version | Time is now: 26th June 2024 - 02:56 AM |
