Experimental Cam for 2.0 w/ variable timing, plus pic's |
76-914 |
Feb 13 2011, 08:36 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,647 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
In a prior post I mentioned that I was going to pull the drive train to check out the p/o's alledged rebuild. They said that they couldn't get it to idle. I found alot of blue silicone from the rebuild. Not good. Coupled with the fact that they had installed a hodge podge of FI components I decided to check out this ol' boys work. P&C's looked pretty new (I'll let the machine shop decide that) so I was hoping that everything else was too.
I almost (IMG:style_emoticons/default/stromberg.gif) in my shoes when I pulled the oil pump. This bolt is not only bent but had backed out 3 threads. The one below it was hand tight. looking at the back side you can see the difference in bolt lengths They had to have heard this. |
SLITS |
Feb 13 2011, 08:41 PM
It is hard to tell if they purposely made the cam timing adjustable by enlongating the mounting holes of if that occured due to the fastner head hitting the oil pump.
On the stand, you should have not been able to turn it by hand. Nice job! |
Jake Raby |
Feb 13 2011, 09:54 PM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
This was common around Y2K.. A whole batch of cam gears ending up being soft and they'd not hold torque.. It happened to me on one occasion.
Also, the oil pump drive tang is protruding too deep into the drive slot of the cam.. See those two shiny spots where the corners of the oil pump drive have been hitting deep inside the drive slot?? I bet the cam thrust bearings are trashed and the cam is walking fore and aft in the case, that could be why the bolts contacted the oil pump as well. Start taking it apart. This post has been edited by Jake Raby: Feb 13 2011, 09:57 PM |
McMark |
Feb 13 2011, 10:13 PM
Yup, nothing good there. Take it apart and build something new. Those are some nasty pics. |
silver74insocal |
Feb 13 2011, 11:59 PM
Senior Member Group: Members Posts: 736 Joined: 26-November 09 From: rancho cucamonga Member No.: 11,073 Region Association: Southern California |
what a great excuse to build a new engine! (IMG:style_emoticons/default/smilie_pokal.gif) maybe a conversion (IMG:style_emoticons/default/idea.gif) we need a subie around here...you go first?
sean_v8_914 |
Feb 14 2011, 09:55 AM
Custom with a C = good
Kustom with a K = that might kinda work Qustom with a Q = questionable Zustom with a Z =because it makes no sense at all |
76-914 |
Feb 14 2011, 09:38 PM
This was common around Y2K.. A whole batch of cam gears ending up being soft and they'd not hold torque.. It happened to me on one occasion. Also, the oil pump drive tang is protruding too deep into the drive slot of the cam.. See those two shiny spots where the corners of the oil pump drive have been hitting deep inside the drive slot?? I bet the cam thrust bearings are trashed and the cam is walking fore and aft in the case, that could be why the bolts contacted the oil pump as well. Start taking it apart. I see it now that you point it out. I wouldn't have known if you hadn't said, thx. Todd at RIMCO mentioned that the oil pump wasn't original and it need to be brazed on the other side of the scarring.(yep, stripped it and dropped it off to them today) That time frame for the bad timing gears is exactly spot on with what the p/o had said. It's getting a Raby 9550 kit w/8300 gear, as soon as they call back to say the case is good. what a great excuse to build a new engine! (IMG:style_emoticons/default/smilie_pokal.gif) maybe a conversion (IMG:style_emoticons/default/idea.gif) we need a subie around here...you go first? If I somehow ended up with a nice Boxter needing an engine, I would do it but not on my 914. |
'73-914kid |
Feb 14 2011, 09:58 PM
Senior Member Group: Members Posts: 1,473 Joined: 1-November 08 From: Vista, CA Member No.: 9,714 Region Association: Southern California |
Dont forget Yustom with a Y Sean, for Why the hell would you you ever do something like that!?
That looks horrendous Kent... Looks like it was run a long time like that. Lok forward to seeing everything back together, and the black car on the road! -Ethan |
Woody |
Feb 14 2011, 10:11 PM
Sandbox Rabblerouser and head toilet scrubber Group: Members Posts: 3,858 Joined: 28-December 10 From: San Antonio Texas Member No.: 12,530 Region Association: Southwest Region |
Can't believe that thing would idle at all.
HarveyH |
Feb 15 2011, 07:25 AM
Member Group: Members Posts: 450 Joined: 19-June 03 From: Downingtown, PA Member No.: 843 |
Happened to me too. PO had the engine rebuilt and modded (2056 cam & Webers) and about 5 years after I bought it a tick developed. Apparently the PO's builder didn't peen or locktite the cam gear bolts and three of them started walking out and eating the oil pump. My mechanic (since retired (IMG:style_emoticons/default/hissyfit.gif) ) was an old-school guy who had been doing street and race Porsches since the late 60's. We decided he would do a long term rebuild project and use the engine to teach his son how to do Type IV's so it was measured, assembled, measured, taken back apart, and so on several times before it was buttoned up the final time. Took 6 - 8 months, but the results were worth it.... Unfortunatly, I have to find a new mechanic now.....
silver74insocal |
Feb 24 2011, 09:26 PM
(IMG:style_emoticons/default/popcorn[1].gif) any word?
76-914 |
Feb 24 2011, 10:41 PM
Not yet. I'm calling them tomorrow = urgency = that's gonna cost me. (IMG:style_emoticons/default/blink.gif)
rick 918-S |
Feb 25 2011, 12:01 AM
Hey nice rack! -Celette Group: Members Posts: 20,826 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Does anyone else see what looks like a crack in the cam flange starting at the short bolt on the left?
Attached image(s) |
76-914 |
Feb 25 2011, 09:09 AM
Does anyone else see what looks like a crack in the cam flange starting at the short bolt on the left? Good eye, Rick. When looking at from a side view. the material actually raises a bit where the 2 cracks are. But I really wasn't going to re-use it, honestly. (IMG:style_emoticons/default/happy11.gif) |
stugray |
Feb 25 2011, 09:58 AM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I hate to say it, but if you had been in CO, I might say that was my old engine from college ~20 years ago.
Back then I bought the High Output pump from AA, and they never mentioned that I would have a clearance issue, so I put it together just like stock. Never heard any ticking clicking or banging. So the person I sold it to probably had issues later. Oh well.... live & learn. Stu |
76-914 |
Feb 25 2011, 10:41 AM
I hate to say it, but if you had been in CO, I might say that was my old engine from college ~20 years ago. Back then I bought the High Output pump from AA, and they never mentioned that I would have a clearance issue, so I put it together just like stock. Never heard any ticking clicking or banging. So the person I sold it to probably had issues later. Oh well.... live & learn. Stu If I don't hear any "ticking clicking or banging" it ran out of gas. (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/laugh.gif) |
majkos |
Feb 25 2011, 11:10 AM
Senior Member Group: Members Posts: 1,370 Joined: 29-February 04 From: Mile High 914 Member No.: 1,729 Region Association: Rocky Mountains |
76-914 |
Feb 25 2011, 09:58 PM
No. Different one. I FU'd again. I got another one. A black 73. Hope your move goes well and that Henna adjusts.
Lo-Fi Version | Time is now: 27th December 2024 - 05:53 AM |
