RiqueMar |
Enrique Allen Mar ![]() ![]() ![]() ![]() Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California ![]() ![]() |
Heyguys, I'm looking for this and I've tried a few things on the search function, but I can't seam to find the proper values for the valves on this 2.7, any knowledge for a young dumb rookie?
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
0.004" cold for both.
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Valve clearances for 911 engines with adjustable valve lash are .004". They need to be right on the money, especially for the earlier engines.
The Cap'n |
RiqueMar |
Heyguys, I'm looking for this and I've tried a few things on the search function, but I can't seam to find the proper values for the valves on this 2.7, any knowledge for a young dumb rookie? Think I got it off the bird board....Here ---> Valve Adjustment Can anyone confirm? |
RiqueMar |
0.004" cold for both. Valve clearances for 911 engines with adjustable valve lash are .004". They need to be right on the money, especially for the earlier engines. The Cap'n Awesome guys, thanks for the help!I'm glad to see the 'Pro's' are on right now! (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) |
SLITS |
make sure you get the tool with spare blades ... makes it much easier (kinda)!
Cap'n Krusty |
Wayne's "911 Valve Adjustment Made Easy" shows you the hard way, but that's OK. ALWAYS adjust the valves BEFORE you remove the spark plugs. Too easy for a piece of carbon to be dislodged and fall into the opening for the exhaust valve, making your adjustment way off.
You can use my easy valve adjustment method (which can be found in the Classic Threads forum). Rock one valve all the way open, adjust the opposite valve. Piece o'cake. In the car, you use a starter button, out of the car, you use a 19mm (3/4") box wrench on the crankshaft pulley. The Cap'n |
Downunderman |
Senior Member ![]() ![]() ![]() Group: Members Posts: 852 Joined: 31-May 03 From: Sydney, Australia Member No.: 766 Region Association: Australia and New Zealand ![]() |
I do it this way.
http://www.pelicanparts.com/techarticles/9...valveadjust.htm I have found it to be more accurate. |
Cap'n Krusty |
I do it this way. http://www.pelicanparts.com/techarticles/9...valveadjust.htm I have found it to be more accurate. Sounds like a lot more work (especially with the engine installed in a 911, much less a 914 where access is severely compromised), and I doubt it's more accurate than my technique. The Cap'n |
Lo-Fi Version | Time is now: 26th June 2024 - 08:29 AM |
