914-6 oil tank question - too many orifices? |
moparrob |
Feb 16 2011, 09:30 PM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
For the longest time I was having difficulty trying to picture where the oil lines go to and from on a 914-6 conversion - but I think I have most of the issues figured out.
A lot of the problem has to do with the tank I bought. It has 'extra' holes and fittings that most other tanks I have seen did not have. Here is a pic: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1297913412.1.jpg) I finally figured out that fitting 'C' is the AN -12 return line which is usually a hard pipe from the engine which attaches to a flex line to this port. Similarly, I figured that fitting 'D' is the supply line that goes to the oil cooler, which in my case is AN -16 on both ends. The confusion arises out of fittings 'A' and 'B'. Most tanks I see do not have these fittings. Also, my car was only pre-drilled (by the PO) for fittings C,D, the filler, the vent and the filter only. I don't have extra holes for these fittings. So, do I need these fittings A and B? What do they do? If I don't need them, how do I get rid of them? Do I have to braze the holes shut? Or is it easier to just drill the two requisite holes in the engine compartment and use plugs on those fittings? Last question, does anyone know the size and thread of those fittings? Thanks in advance for your help. Rob |
SLITS |
Feb 16 2011, 09:35 PM
I can't remember if those are for an automatic transmission (some tanks had extra fittings) or some type of PO installed item.
Based on the "B" position, that would be supply and the "A" the return. You only need "C" & "D" Anyway, the experts will chime in in a moment. Oh, I would say 3/8" pipe fittings. |
mepstein |
Feb 16 2011, 10:01 PM
914-6 GT in waiting Group: Members Posts: 19,731 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
A lot more fittings than my OEM tank. I know there was a different version for the Sportomatic but I've never seen one in person. Maybe look at PET?
sixerdon |
Feb 16 2011, 10:13 PM
Member Group: Members Posts: 466 Joined: 23-May 03 From: Dartmouth, MA Member No.: 731 |
That is a sporto tank. Back in the 70's, I bought one to replace a leaking one in my /6 at the time. Stock tanks were already hard to find, but sporto's were available. What I did is take a copper penny (1981 or earlier) and brazed it over the openings. Never had a problem with leaks for the remaining time that I owned it.
Don |
Cap'n Krusty |
Feb 16 2011, 10:28 PM
I can pretty much guarantee they're not 3/8ths pipe. Might want to check in the metric section of any good hardware supplier ........................
The Cap'n |
moparrob |
Feb 16 2011, 10:30 PM
I wonder if they are pipe thread (taper) so that I could use a plug? Otherwise, if it is a straight thread I guess it would seal on the top surface with an aluminum washer?
Or perhaps I could unscrew those fittings and find threaded caps? |
Eric_Shea |
Feb 17 2011, 10:34 AM
PMB Performance Group: Admin Posts: 19,291 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Sporto. I'd take it down, have it properly welded, re-copper plated and re-painted.
SirAndy |
Feb 17 2011, 11:43 AM
Resident German Group: Admin Posts: 42,036 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
scotty b |
Feb 17 2011, 11:45 AM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
MMMmmmmm AAHHHHhhhhhhhhhhh toasty radiant heat (IMG:style_emoticons/default/rolleyes.gif)
Cap'n Krusty |
Feb 17 2011, 12:19 PM
I wonder if they are pipe thread (taper) so that I could use a plug? Otherwise, if it is a straight thread I guess it would seal on the top surface with an aluminum washer? Or perhaps I could unscrew those fittings and find threaded caps? I repeat. They're metric fittings, NOT pipe thread. Just get a couple of plugs, a couple of copper gaskets, and be done with it. The Cap'n |
laflaur |
Feb 17 2011, 12:46 PM
Member Group: Members Posts: 162 Joined: 8-June 06 From: Granite Bay Member No.: 6,186 Region Association: Northern California |
Hey are those pipe thread fittings?
moparrob |
Feb 17 2011, 02:18 PM
(IMG:style_emoticons/default/stirthepot.gif)
Cap'n, I was trying to avoid cutting two additional holes for those fittings to stick out of, but your advice is well taken. That may be the easier course of action. Now if I could only figure out where the heck to layout the holes before I start drilling ... (IMG:style_emoticons/default/confused24.gif) |
SirAndy |
Feb 17 2011, 03:02 PM
Now if I could only figure out where the heck to layout the holes before I start drilling ... (IMG:style_emoticons/default/confused24.gif) I would think that a stock 914-6 sport-o-matic oil tank would be worth more to the right buyer than a standard tank ... Why not sell it and buy a correct one and pocket some money in the process??? (IMG:style_emoticons/default/confused24.gif) They made only what, 25 914-6 sportos? (IMG:style_emoticons/default/idea.gif) |
jeff |
Feb 17 2011, 04:13 PM
Member Group: Members Posts: 254 Joined: 17-January 04 From: thousand oaks,ca Member No.: 1,570 |
moparrob |
Feb 17 2011, 05:06 PM
Now if I could only figure out where the heck to layout the holes before I start drilling ... (IMG:style_emoticons/default/confused24.gif) I would think that a stock 914-6 sport-o-matic oil tank would be worth more to the right buyer than a standard tank ... Why not sell it and buy a correct one and pocket some money in the process??? (IMG:style_emoticons/default/confused24.gif) They made only what, 25 914-6 sportos? (IMG:style_emoticons/default/idea.gif) Hmmm, not a bad idea. Think I'll give it a try.... |
moparrob |
Feb 17 2011, 05:08 PM
Except those are tapered threads and per prior posting the threads are not tapered... |
SLITS |
Feb 17 2011, 06:28 PM
(IMG:style_emoticons/default/stirthepot.gif) Cap'n, I was trying to avoid cutting two additional holes for those fittings to stick out of, but your advice is well taken. That may be the easier course of action. Now if I could only figure out where the heck to layout the holes before I start drilling ... (IMG:style_emoticons/default/confused24.gif) You can make a cardboard template and register off the other holes to know where to drill if it comes to that. |
Eric_Shea |
Feb 17 2011, 06:42 PM
QUOTE You can make a cardboard template and register off the other holes to know where to drill if it comes to that. This is painful to watch... (IMG:style_emoticons/default/sad.gif) |
SLITS |
Feb 17 2011, 06:50 PM
QUOTE You can make a cardboard template and register off the other holes to know where to drill if it comes to that. This is painful to watch... (IMG:style_emoticons/default/sad.gif) Close your eyes and the pain will go away! (IMG:style_emoticons/default/slap.gif) |
hwgunner |
Feb 17 2011, 08:29 PM
914 Parts @ Discount Prices 800.321.5432 Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None |
QUOTE You can make a cardboard template and register off the other holes to know where to drill if it comes to that. This is painful to watch... (IMG:style_emoticons/default/sad.gif) Close your eyes and the pain will go away! (IMG:style_emoticons/default/slap.gif) Well said! (IMG:style_emoticons/default/sheeplove.gif) |
Lo-Fi Version | Time is now: 5th February 2025 - 01:06 PM |
