> Electrical Question, what happens to the amp rating
76-914
post Feb 18 2011, 04:32 PM
If I am using a switch that is rated for 16A @125vac in a 12vdc application does the amp rating of the switch also change?
Mike Bellis
post Feb 18 2011, 04:37 PM
Resident Electrician
The amp rating is based on the gauge of the conductor. If you need 16A of 12V, you should use the switch to throw a relay.
messix
post Feb 18 2011, 07:03 PM
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
Ohms law. Amp x volts=watts watts/volts=amp
zonedoubt
post Feb 18 2011, 08:43 PM
Canadian Member
QUOTE(messix @ Feb 18 2011, 05:03 PM) *
Actually, that's Joule's Law. Ohm's law is V=IR.
zonedoubt
post Feb 18 2011, 09:02 PM
Canadian Member
QUOTE(76-914 @ Feb 18 2011, 02:32 PM) *
Use the DC rule of thumb: the highest AC amperage rating on the switch should work up to 30 VDC. In this case, the switch can probably handle 16A up to 30 VDC. But this depends on the switch...check the specifications if in doubt.
post Feb 18 2011, 09:29 PM
Thx, it's just a small winch motor that makes a 30 sec run once a week. I wanted to be sure the switch was large enough.
EDIT: I'm guessing it's less than 4 amp
- Lo-Fi Version Time is now: 27th December 2024 - 08:02 AM
