That can't be right, How should the throttle cable look at firewall?? |
PDXMike |
Feb 18 2011, 09:39 PM
Slowly Learning Group: Members Posts: 111 Joined: 20-December 10 From: Portland, OR Member No.: 12,501 Region Association: Pacific Northwest |
So this what the throttle cable exit at my firewall looks like. That can't be right. The tube is not attached to the firewall, and the threaded end of the cable wouldn't slide out. The string in the picture was used to pull the cable perpendicular to the firewall. Needless to say, this wasn't working very well.
What should this look like? What do I need to do? |
Kirmizi |
Feb 18 2011, 10:26 PM
Senior Member Group: Members Posts: 836 Joined: 12-February 06 From: Wyoming, US Member No.: 5,568 Region Association: None |
Attached image(s) |
Spoke |
Feb 18 2011, 10:31 PM
Jerry Group: Members Posts: 7,104 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
It looks like the tail-end of the throttle cable tube broke off. The easiest thing would be to remove the cable, find the end piece in the cable sheath and weld it back on.
roadster fan |
Feb 18 2011, 10:37 PM
Project Frankenstein !!!!!!!! Group: Members Posts: 1,009 Joined: 24-November 05 From: Aptos, CA Member No.: 5,184 Region Association: Northern California |
looks like someone may have tried to fix that once before. Here is a pic from a thread about the clutch tube repair that has to be done quite often on these cars.
Hope this helps with your initial question. Do a search for clutch tube repairs and you will find lots of photos of the area in question. Someone will chime in who has actually repaired the throttle cable tube i am sure. Jim |
dr914@autoatlanta.com |
Feb 19 2011, 10:36 AM
914 Guru Group: Members Posts: 8,110 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
get thee to a welding shop!. The clutch tube broke badly years ago and someone improperly rigged it affecting the accelerator cable tube. The fix is relatively easy
So this what the throttle cable exit at my firewall looks like. That can't be right. The tube is not attached to the firewall, and the threaded end of the cable wouldn't slide out. The string in the picture was used to pull the cable perpendicular to the firewall. Needless to say, this wasn't working very well. What should this look like? What do I need to do? |
Lo-Fi Version | Time is now: 27th December 2024 - 08:09 AM |
