front cooler install begins |
moparrob |
Feb 19 2011, 08:04 PM
Senior Member Group: Members Posts: 646 Joined: 27-April 10 From: Los Angeles Member No.: 11,663 Region Association: None |
Today I tackled one of the most painful projects to date - tearing out the metal shelf for the front trunk spare cover. It was in the way of where my RX-7 cooler needs to mount so out it came.
It was painful because I could not cut the spot weld below the headlight assembly, so I basicall used an air chisel to rip the metal out. Here is the shelf with the spot weld cut: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1298167493.1.jpg) Here is the same area with the shelf removed: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1298167494.2.jpg) And this is the torn up sides which will need to be repaired: (IMG:http://www.914world.com/bbs2/uploads_offsite/i954.photobucket.com-11663-1298167494.3.jpg) Now it is on to designing and fabricating the cooler mounts.... |
gothspeed |
Feb 20 2011, 12:47 PM
Senior Member Group: Members Posts: 1,539 Joined: 3-February 09 From: SoCal Member No.: 10,019 Region Association: None |
Is this on a type 4? I am curious if it is not too long of a distance for a stock oil pump with a 'sandwich' adapter.
moparrob |
Feb 20 2011, 02:09 PM
No, I've got a 3.0 from a '79 SC that is going to be installed, along with the stock 914-6 oil tank, RX-7 cooler and a Mocal thermostat.
Lo-Fi Version | Time is now: 27th December 2024 - 10:08 AM |
