1.8 case dimentions |
tracer |
Feb 23 2011, 09:23 AM
Newbie Group: Members Posts: 44 Joined: 26-July 04 From: El Dorado Hills, CA Member No.: 2,405 Region Association: Northern California |
Hi Everyone, Does anyone know what the hole opening size is for the cylinders to fit into the case. I measure 100mm which I believe is the stock size. Reason I am asking is the previous owner of this engine installed oversizes piston/cylinders which bumped the 1.8 up to 1.9 I believe. I see some milling is present on the heads but that is all I can see so far.
Cap'n Krusty |
Feb 23 2011, 09:36 AM
Most likely he used the readily available aftermarket cylinders which require no case machining. In fact, most kits don't require the heads to be opened up, either.
The Cap'n |
tracer |
Feb 23 2011, 10:25 AM
Great, That's what I thought. Thanks
Lo-Fi Version | Time is now: 27th December 2024 - 02:12 AM |
