temp sending unit |
temp sending unit |
ruddyboys |
Apr 30 2004, 02:28 PM
Hummel eigentümer Group: Members Posts: 595 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
How do I test to see if temp sending unit is bad and to check if the console gauge is bad.
Mueller |
Apr 30 2004, 02:43 PM
914 Freak! Group: Members Posts: 17,150 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None |
warm water???
or use a volt meter, both work on resistance not too sure of the values, if you do a search for Ander's 914 D-jet website, he should have the ohm values and range |
dmenche914 |
Apr 30 2004, 10:41 PM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
assuming you want to test the oil temp sender, remove the sender, and leave it attached under the car. Attach a terst lead tot he sender, and ground it to the engine
Get a camp stove, or hot plate, or electric coffe pot and boil water in a pot under the car (raise the car), with grounder sender in the pot, you should see the gage go to 212F if you are at sea level. Adjust the calibration for high altitude if need be. Alternate method if no camp stove or hot plate would be to boil water on your house stove (bigger pot the better, want big thermal mass) and bring it out to the sender. have a good thermometer in the hot water, and place the grounder sender in it. after a minute or so the temps shouild be in equalibriium (sender to the thermometer) and see were the gage pointer goes,and note temp on thermometer. If gage does not read correctly, cheack all electric connections. assure you have correct part number on sender for the gage. |
Lo-Fi Version | Time is now: 5th January 2025 - 12:42 AM |
