alternator not charging |
biker bob |
Apr 6 2011, 02:47 PM
Member Group: Members Posts: 53 Joined: 25-March 09 From: Eureks Springs Ar. Member No.: 10,200 Region Association: Southwest Region |
Started the car (72 2.0 L) this morning to go for gas. Alternator light stayed on for about 15 seconds after engine started then went out. Restarted the engine after getting gas and the light went out. Returned home no issues. Restarted engine after about 30 minutes. The alternator light came on and would not go out. Drove around the block and light remained on. Checked charging at battery NO charging.
2000 miles on new belt, new Bosche alternator,and new Bosche voltage regulator. Alternator wires properly plugged into the relay board. Belt properly adjusted. Transmission ground strap clean and tight. Help needed. |
McMark |
Apr 6 2011, 02:49 PM
Clean connection at the starter? Failed wiring harness?
r_towle |
Apr 6 2011, 02:51 PM
Custom Member Group: Members Posts: 24,624 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
give the voltage regulator a good solid tap tap tap and see if it charges.
Seriously. Rich |
Jeffs9146 |
Apr 6 2011, 02:57 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
QUOTE give the voltage regulator a good solid tap tap tap and see if it charges. Seriously. (IMG:style_emoticons/default/agree.gif) If it still doesn't charge remove the voltage regulator and clean the contacts! Then if it still doesn't charge replace the voltage regulator! |
Drums66 |
Apr 6 2011, 02:58 PM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
....after 2000mi alternator& or voltage reg....may be defective?? (IMG:style_emoticons/default/idea.gif)
get system checked! (IMG:style_emoticons/default/bye1.gif) |
biker bob |
Apr 6 2011, 03:14 PM
Clean tight conections at starter. Light still on.
Taping the voltage regulator did not make the light go out. |
r_towle |
Apr 6 2011, 03:20 PM
Sorry to say, pull the alternator and have it bench tested.
Its about a 30 minute job to pull it out the bottom. It does come out.,..and its a PITA. Some of the more recent "bosch" rebuilt starters and alernators are not super reliable. I only bring mine to a local shop (thankfully they exist) that rebuilds them for me... Rich |
biker bob |
Apr 7 2011, 05:23 AM
I have checked everything that has been suggested short of replacing the voltage reg and alternator. The one thing I have noticed is the alternator light is much brighter than normal. Could this be clue as to the problem?
Is there anyway to check the voltage reg other than replacing it? |
jt914-6 |
Apr 7 2011, 05:53 AM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
Make sure you haven't kicked out a fuse getting in. Check all the fuses. Spin them in their holders. If the alt. light fuse is out/bad the light will stay on.....NAPA has a electronic version of the vr...Some Fords used the mechanical type vr''s too...
Spoke |
Apr 7 2011, 06:32 AM
Jerry Group: Members Posts: 7,052 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
You can check the alternator in the car by disconnecting the VR and shorting the D+ and DF wires together from the alternator. This is equivalent to the VR asking the alternator to provide full charging. If the alternator is ok, you should see 16V or so on the battery.
BTW, the fuse you want to check is S9. S9 also powers the oil warning light so if that light is lit when you turn the key on, then S9 is ok. |
biker bob |
Apr 7 2011, 08:55 AM
One last thing to add. The brake warning light is blinking and will not stop after engine starts. It did stop blinking when the engine started before the alternator light started staying on. Thanks everyone for your suggestions and help.
Bob |
Spoke |
Apr 7 2011, 09:41 AM
About my little test, I should have added one more thing in this and it gets to a startup sequence with these alternators.
When you short D+ and DF together, this does tell the alternator to produce full charge. But you still need the alternator light connected to provide a bit of charge to "bootstrap" the voltage. In other words, the light provides that little bit of electric current to start the alternator to produce voltage then D+ will power DF on its own and then you will be testing the alternator. So, modified alternator test is this: 1) Remove VR. 2) Place a wire between D+ (spade towards front-right of car) and DF (spade towards front-left of car). This keeps the alternator light in the circuit for bootstrap purposes. 3) Start car, rev engine, measure battery voltage. Alternator light should go out too. |
76-914 |
Jun 23 2011, 10:44 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,611 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Some great info here. Is there a way to bench test the alt at home? I tried several FLAPS a few years ago and none were able to bench check our externally regulated alt's. (IMG:style_emoticons/default/confused24.gif)
Dave_Darling |
Jun 23 2011, 04:36 PM
914 Idiot Group: Members Posts: 15,048 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
Brake light: Make sure the handbrake handle is down, pressing the button in the floor. Also try to reset the switch in the master cylinder; there should be a button covered by a rubber nipple. Press the button to reset the switch.
--DD |
Lo-Fi Version | Time is now: 25th September 2024 - 07:10 AM |
