falconfp2001 |
Pancho Pantera ![]() ![]() Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region ![]() |
I am missing the solid mounts for my side shift conversion. They go on the ends of the bar and fasten to the frame.
Will pay pal for a reasonable price by Wednesday Thanks Attached image(s) ![]() |
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
What part? The metal piece that the bar bolts to? The one in the photo? I have them if you need them?
falconfp2001 |
What part? The metal piece that the bar bolts to? The one in the photo? I have them if you need them? Yes the one circled is 30.00 plus 5.00 for priority mail good? I'll paypal for Wednesday if that' good. thanks Attached image(s) ![]() |
Jeffs9146 |
I am sure that is more than I need! I will pull them off and try to get them out tomorrow!
You need both of them right! PM me your info and I will send you my paypal info! Attached thumbnail(s) ![]() |
914Mike |
Member ![]() ![]() Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 ![]() |
I am missing the solid mounts for my side shift conversion. They go on the ends of the bar and fasten to the frame. Will pay pal for a reasonable price by Wednesday Thanks You can make those out of two pieces of angle iron, cut to length and drilled. I made one when I came up short after a long rebuild. The missing one just turned up, so I took the sub out yesterday. I say two pieces of angle iron, that means two per side, doubled up on the bottom to make a channel like the original. If you use 1/8" thick angle, about 1" by 1" works, and is actually stronger than the original. The sides being taller made it harder to put the nut on the bolt, that's the only drawback I noticed. |
Jeffs9146 |
Parts pulled, cleaned & packed ready for shiping! I didn't know if you needed the bolts also so I included all 6 bolts, nuts and washers!
If you want these by wednesday drop me a paypal and they will go out today! |
Jeffs9146 |
Shipped today!
Lo-Fi Version | Time is now: 23rd June 2024 - 01:17 PM |
