Bullet |
Member ![]() ![]() Group: Members Posts: 116 Joined: 16-April 04 From: Newberg, OR Member No.: 1,940 ![]() |
Tomorrow im firing up the car for the first time since i have owned. And i got everything wired up all the vacuum hoses hooked up. But i noticed that i dont have the red wire for the Aux air vale connected to anything. I looked around for an open wire and found nothing. Where does this wire go? am I missing something?
Eric Taylor |
Senior Member ![]() ![]() ![]() Group: Members Posts: 909 Joined: 1-June 03 From: Newport, OR/Eugene Oregon- UO Member No.: 770 ![]() |
there should be an open connection on the ignition harness. just a little plastic covered connection with a white wire coming off of it.
Bullet |
Damn maybe i hooked that up wrong then. the only wire that i can think of off the ecm harnessthat has a plastic conector is what i hooked up yo the Temp sensor. and then i hooked up the plactic connector on the harnees which goes to the starter is going to the Oil pressur switch. Did i goof some were?
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
hmmm, on my diagram, the wire to the AAR looks white, and seems to come from pin12 of the engine harness connector on the relay board.
Attached image(s) ![]() |
Bullet |
Well shit. i wish that i had the car here at my house so i could go do dsome looking. If i cant find this wire for some reason. Will the car run like crap without it?
SirAndy |
QUOTE(Bullet @ May 7 2004, 11:23 PM) Will the car run like crap without it? yes, if the vac-hoses are still connected to the AAR but it doesn't have any juice, the car will hunt idle when warm and drive "strange" ... if you can't find the wire, disconnect & plug the 2 hoses that go to it. you will have very low idle when cold, but everything will be correct once the engine gets to operating temp (including the idle) ... Andy |
Bullet |
Kool, Thanks for the help. I cant wait to drive it for the first time.
JeffBowlsby |
914 Wiring Harnesses ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,575 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None ![]() ![]() |
QUOTE Damn maybe i hooked that up wrong then. the only wire that i can think of off the ecm harnessthat has a plastic conector is what i hooked up yo the Temp sensor. and then i hooked up the plactic connector on the harnees which goes to the starter is going to the Oil pressur switch. Did i goof some were? Yep you got it wrong. The long plastic box housing on the fuel injection harness goes to Temp Sensor 2 at cyl #3. I think you got that from your post. The green/red stripe wire from the ignition harnes (no plastic box housing) goes to teh oil pressure sender at the top of the engine, and the white wire off the ignition harness with the plastic box housing goes to the red wire on the AAR. |
Lo-Fi Version | Time is now: 26th June 2024 - 08:02 AM |
