Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Z... we've already seen your hairy ass so you need not post it here. (IMG:style_emoticons/default/bootyshake.gif)
I'm looking for antenna locations for the "Passengers Side" only. Can you post some pictures gang? Thanks! |
skline |
Born to Drive ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,910 Joined: 26-December 02 From: Costa Mesa, CA Member No.: 17 Region Association: Southern California ![]() |
Sure, no problem. Mine is on the passenger side which is where I believe it should be. There was even a grommet there for the antenna cable to go through. ope this helps you. Its a Hirshman power antenna.
Attached thumbnail(s) ![]() |
skline |
Here is one a little closer up.
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
Here's mine. I want to use a grommet to cover the hole for now until I put in a power ant. after it has a radio (IMG:style_emoticons/default/wink.gif)
Attached image(s) ![]() |
Lo-Fi Version | Time is now: 27th June 2024 - 04:48 AM |
