Bullet |
Member ![]() ![]() Group: Members Posts: 116 Joined: 16-April 04 From: Newberg, OR Member No.: 1,940 ![]() |
I'm trying to remove my pedal cluster so that i can replace the pedal bushings. I was able to remove the 2 nuts towards the drivers seat. But the 2 against the bulk head i cant get a soket on them. I crawled way up under there to take a closer look and see what looks like welds on the bold heads. At first i thought it was just some corrosion but after about 50 hard whacks with a chisle i am convinced that they are welds. My qestions is: how the hell do i get theese last 2 bolts out?
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
wrong side !!!!!
you need to access the two nuts from underneath the vehicle (IMG:style_emoticons/default/wink.gif) you cannot use a socket, a 13mm open/closed wrench is a better tool |
Kargeek |
Senior Member ![]() ![]() ![]() Group: Members Posts: 555 Joined: 14-March 03 From: Orange, CA Member No.: 430 ![]() |
I believe they are studs that go through the floor of the car and master cylinder. So, take the nuts off the M/C and you can then get it out. DH
Mueller |
oh yea, they are not bolts, they are studs which are permenetly attached to the pedal cluster assembly.
Bullet |
Shit!!!! i wish that i would have thought about that. I have been so pissed off at this for the last couple of weeks that i have not even touched that car. Thanks alot! I will pull it all out tomorrow.
Mueller |
QUOTE Shit!!!! i wish that i would have thought about that. i feel your pain....it's the little things that always get me....make it hard or difficult from the get-go and it's easy to figure out, but make it a simple-simon problem and it'll kick my ass, LOL |
Levi |
Lick my nuts ![]() ![]() ![]() Group: Benefactors Posts: 623 Joined: 11-March 04 Member No.: 1,783 ![]() ![]() |
QUOTE(Bullet @ May 25 2004, 10:12 PM) Shit!!!! i wish that i would have thought about that. I have been so pissed off at this for the last couple of weeks that i have not even touched that car. Thanks alot! I will pull it all out tomorrow. Hehehe...have you tried to remove the starter yet..... (IMG:style_emoticons/default/lol2.gif) Don't ask.... (IMG:style_emoticons/default/chairfall.gif) |
Trekkor |
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California ![]() |
Actually, the studs are tack welded to the pan. The ped-assym is fitted over the studs and held in place with 13mm nuts. This area is a rust pond if water leaks into your car...Like mine.
I just did this. The studs will shear off. Use an air chisel to press the old studs out. Have an assistant help you by holding a wrench on new bolts or weld in new studs. No problem! |
dinomium |
Git on a chair son, all the good stuff is goin over yer head! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,777 Joined: 2-January 03 From: Bremerton, WA Member No.: 74 Region Association: Pacific Northwest ![]() ![]() |
CUBS Win CUBS WIN!! |
Bullet |
QUOTE(Levi @ May 25 2004, 10:28 PM) QUOTE(Bullet @ May 25 2004, 10:12 PM) Shit!!!! i wish that i would have thought about that. I have been so pissed off at this for the last couple of weeks that i have not even touched that car. Thanks alot! I will pull it all out tomorrow. Hehehe...have you tried to remove the starter yet..... (IMG:style_emoticons/default/lol2.gif) Don't ask.... (IMG:style_emoticons/default/chairfall.gif) I just replaced the starter before i installed the Engine. So i havent had the Pleasure of doing it with it installed on the car. Is the Pain trying to hold the bolt with a wrench on the engine side of the bellhousing while trying to losen it up on the starter at the same time? |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,712 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
QUOTE(Bullet @ May 26 2004, 12:21 PM) Is the Pain trying to hold the bolt with a wrench on the engine side of the bellhousing while trying to losen it up on the starter at the same time? if that was how it worked, it would be too easy. (IMG:style_emoticons/default/wink.gif) the bolt is "supposed" to have a flat spot on the head that keeps it from turning (on the starter side) so that you can just unbolt the nut from the engine comp side. thing is, most of them are round by now. try to get you hand in there to hold the bolt (on the starter side) while turning a wrench in the engine comp. <_< Andy |
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Woa... the studs are "not" tack welded to the pan. Unless you mean the small pedal assembly pan. They're not studs either. They're actual bolts that "are" welded to the pedal assembly pan, hence you saw "heads" and you were trying to turn them. They effectively act as studs though.
Andy is correct. You simply need to go under the car and remove the two 13mm nuts holding these bolts/studs in. They don't need to be chiseled out unless you want a boat load of extra work that is totally unnecessary. If your car has a suspension cover those two nuts should come off fine. Use penetrating oil and a MAP torch but by all means don't chisel off the bolts. Let me know if you want detailed pictures. I have a completed pedal assembly out of the car so you can see the layout. |
Eric_Shea |
Had the camera out so I took some pics... the nuts hold the master cylinder on as well.
Attached image(s) ![]() |
Eric_Shea |
Here's the inside view showing the welds on the bolts...
Eric_Shea |
The pictures may seem unclear because the body is actually sandwiched between the master cylinder and the pedal assembly. Hope that helps.
Trekkor |
Those aren't the bolts in question. It's the welded from under the car studs that hold the ped assym down to the floor behind the gas pedal. The ped assym attaches in two places, through the front bulkhead and m/c and over the floor pan studs.
(IMG:style_emoticons/default/agree.gif) chiseling off the master/cylider bolts would be a HUGE mistake. |
Bullet |
I got the pedals out today. OMG there were a ton of spiders on the nuts by the M/C. OHH yeah I HATE SPIDERS!!. I removed all the pedals today and cleaned them up with a wire wheel and brush. removed all the Nylon bushings, and am ready to put it all back together. I was trying to decide whether it was worth the $$ to get the goods powdercoated or if i should just repaint it. Powder coat would look good, but then who is ever going to see this.
Levi |
QUOTE(Bullet @ May 26 2004, 06:25 PM) I was trying to decide whether it was worth the $$ to get the goods powdercoated or if i should just repaint it. Powder coat would look good, but then who is ever going to see this. Good thinking..save your money for other good stuff. (IMG:style_emoticons/default/beerchug.gif) |
Eric_Shea |
QUOTE I was able to remove the 2 nuts towards the drivers seat. But the 2 against the bulk head i cant get a soket on them. I crawled way up under there to take a closer look and see what looks like welds on the bold heads. QUOTE Those aren't the bolts in question. Hmmmmmmmmmmmmmm... (IMG:style_emoticons/default/confused24.gif) |
Eric_Shea |
QUOTE I was trying to decide whether it was worth the $$ to get the goods powdercoated or if i should just repaint it. Powder coat would look good, but then who is ever going to see this. I used POR15 on mine. Get a can of the stuff for around $25 bucks you'll never regret it. |
Lo-Fi Version | Time is now: 1st July 2024 - 07:06 AM |
