clutch pivot shims |
mightyohm |
May 26 2004, 06:44 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
How do you determine the shim thickness for the clutch pivot?
Say I do not know if the pivot was adjusted correctly before (the fork was rubbing on the pressure plate) and I just had the flywheel resurfaced. How do I know if it's adjusted correctly now? What is the thickness of the stock shim supposed to be? Can I measure the flywheel in some way and come up with a number for the addtional shim amount? |
mightyohm |
May 27 2004, 09:32 PM
bump
Brad Roberts |
May 28 2004, 01:16 AM
No one likes you Jeff :finger2:
B |
ChrisFoley |
May 28 2004, 01:46 AM
I am Tangerine Racing Group: Members Posts: 7,937 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
QUOTE(jkeyzer @ May 26 2004, 08:44 PM) How do you determine the shim thickness for the clutch pivot? Trial and error. Attach the tranny to the engine and check the position of the fork and the amount of free play. |
mightyohm |
May 28 2004, 01:49 AM
How much free play should there be?
Thanks! |
ChrisFoley |
May 28 2004, 07:38 AM
I couldn't find a spec on it, but basically you want the fork to have sufficient travel to fully disengage the clutch when the pedal is depressed.
That means the fork should be towards the front of the opening in the side of the bellhousing when the engine and gearbox are together. You just don't want it so far forward that there is any interference. |
bondo |
May 28 2004, 08:53 AM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
JFJ914 |
May 28 2004, 09:02 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
The shim shown in the PET is just a washer. Two are about all you can use and still have enough thread on the pivot to secure it.
Lo-Fi Version | Time is now: 26th June 2024 - 01:06 AM |
