Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
Well today i figured out why my car has such a high idle, the throttle body sticks. So if I manually apply pressure to close it with my hand, it idles fine (well I need to tune the idle screws and mixture but still). So that portrays the question.
What would cause the throttle body to stick? I check the TB plate, and unscrewed it and tryed to fit it better, then tightened it down, didnt help. I set the MPS or whatever that thing is called on the TB.. Now im stuck. I can drive the car, but I still want to figure out this problem. Any idea's? Andrew |
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
QUOTE Well today i figured out why my car has such a high idle, the throttle body sticks. So if I manually apply pressure to close it with my hand, it idles fine You do mean the throttle valve? D-Jet or L-Jet? QUOTE I set the MPS or whatever that thing is called on the TB.. You mean the Throttle Position Sensor (TPS)? There used to be a guy that rebuilt throttle valves on 914's. I believe you sent him your valve and he would put new bushings in it for the shaft and make it work like new. I think his name was Mike Cooley and the company was Southern Knight Machining. I never sent a valve to him so I don't know the quality of his work, but it may be worth a look. I think he charged something like $43.00 to do it. |
Andyrew |
76 2.0. so D-jet (right?)
I'll just do whatever work myself. Not keeping the engine that long.. lol. Gona blow up some day. |
John |
Well in any event, I dug up the link:
http://www.tolisgroup.com/porsche/mike-ad.html It does show some cleaned up throttle valves. |
MattR |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,279 Joined: 23-January 04 From: SF Bay Area Member No.: 1,589 Region Association: Northern California ![]() |
QUOTE(Andyrew @ May 26 2004, 08:15 PM) ...Any idea's?... EJ20T (IMG:style_emoticons/default/biggrin.gif) |
Rusty |
Wanted: Engine case GA003709 ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 7,943 Joined: 24-December 02 From: North Alabama Member No.: 6 Region Association: Galt's Gulch ![]() ![]() ![]() |
QUOTE(JOHNMAN @ May 27 2004, 08:45 AM) Well in any event, I dug up the link: http://www.tolisgroup.com/porsche/mike-ad.html It does show some cleaned up throttle valves. Mike Cooley still hangs out on the Rennlist. He joined the 914 Club recently, but I don't see him post much. I don't think he does these TB overhauls anymore. I know that people that received his work were very pleased with the quality. |
Lo-Fi Version | Time is now: 26th June 2024 - 02:35 AM |
