boston914 |
Member ![]() ![]() Group: Members Posts: 52 Joined: 15-July 03 From: Boston, MA Member No.: 912 ![]() |
Forgive my ignorance, but I have read many posts that reference POR-15.
Can someone tell me exactly what this product is? Where can it be purchased? My car has rustproofing (sticky stuff) in the trunks, door jambs, underneath, etc. Is this POR-15? Thanks. ----------------------------------------- '76 Malaga Red |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
Marlow |
Member ![]() ![]() Group: Members Posts: 311 Joined: 14-August 03 From: Manassas, VA Member No.: 1,027 ![]() |
Por15 is an extremely durable paint. Try www.por15.com for everything about it. They have a great FAQ section. The "sticky" stuff on your car is probably fresh rustproofing. The original rustproofing has usually dried out by now so I doubt it's original stuff. Por15 is rock hard when dry and can be tough to remove once applied. Great for preventing rust on our old cars.
You can buy it directly from the link above or you may find it locally at specialty paint stores. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,707 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
QUOTE(boston914 @ Jun 2 2004, 04:44 PM) My car has rustproofing (sticky stuff) in the trunks, door jambs, underneath, etc. Is this POR-15? nope, that's undercoating! no good after 30 years. it cracks and traps water and then you get RUST ... http://www.por15.com/ (IMG:style_emoticons/default/smash.gif) Andy |
SirAndy |
QUOTE(SirAndy @ Jun 2 2004, 04:53 PM) nope, that's undercoating! btw. in germany, they (the car manufacturers) recommend to clean off old undercoating and re-apply new undercoating every 2 Years! you can imagine how good 30 year old undercoating works (NOT!) ... (IMG:style_emoticons/default/sad.gif) Andy |
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
How do you remove undercoating? The PO of my car sprayed undercoating all over the place, though it seems more durable than the usual rubberized stuff I've seen in the past.
seanery |
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None ![]() |
heat gun and a scraper. Ask Jenny!
vortrex |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,687 Joined: 24-December 02 From: SF, CA Member No.: 4 Region Association: None ![]() |
plumbers torch works good too. just heat it enough to flake off with a putty knife, not until it's gooey or on fire.
SirAndy |
QUOTE(lapuwali @ Jun 2 2004, 05:09 PM) How do you remove undercoating? this is the best way to go ... http://www.carblast.de/ they blast little particles of dry-ice onto it and it'll brake off in chunks without scratching the paint! (IMG:http://www.carblast.de/img/verfahren_skizze.jpg) (IMG:style_emoticons/default/smash.gif) Andy |
TimT |
retired ![]() ![]() ![]() ![]() Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 ![]() |
QUOTE they blast little particles of dry-ice onto it HAH!! we used to use fire extinguishers to "freeze" off mis-applied thermoplastic road stripes I use a rosebud tip on low heat and scrape away...where I can access I just let it catch on fire (IMG:style_emoticons/default/laugh.gif) (IMG:style_emoticons/default/blowtorch.gif) |
IronHillRestorations |
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,735 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None ![]() ![]() |
Eastwood Co. sells a product designed to remove undercoating.
PK (IMG:style_emoticons/default/cool.gif) |
lmcchesney |
Member ![]() ![]() Group: Members Posts: 488 Joined: 24-November 03 From: Ocala, Fl. Member No.: 1,381 Region Association: None ![]() |
I have used Permatex Extend and found this product to be very helpful. What is the difference in Permatex Extend vs POR-15 other than the resulting color of the finished area?
L. McC |
mskala |
R ![]() ![]() ![]() Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None ![]() ![]() |
boston914,
You can see the real stuff here. Or you can see it in person if you want to go north (w. newbury) It is very hard and shiny, but not supposed to see sunlight. part of My Webpage |
djm914-6 |
Happiness is: Getting on the road ![]() ![]() ![]() Group: Members Posts: 1,864 Joined: 6-February 03 From: Burlington MA Member No.: 248 Region Association: None ![]() |
Boston914,
It sounds like you got the same problem as myself. Someone sprayed this sticky black crap inside both trunks, cockpit, valances, rockers and underside. I stripped the cockpit with every method above with little luck. A heat gun worked better than most especially when used with (Kiddies, DON'T try ths at home) GUNK engine degreeser. My last ditch effort to finish my floors was plane, old, ordinary, aircraft stripper (Kinda like the kind you see at the Golden Banana, but this stuff smell better) I'll be doing the POR15 on my battery tray pretty soon. Give me a shout if you want to see it in action. 781/273-4841 |
boston914 |
Thanks Dave.
I was at your event last year. I do not know if you remember my car. Anyway, I am looking forward to another get together. Is the breakfast being scheduled for the 12th? |
aircooledboy |
Sweet Pea's 1st ride in daddy's "vroom -vroom" ![]() ![]() ![]() Group: Members Posts: 1,672 Joined: 4-February 04 From: Rockford, IL Member No.: 1,629 Region Association: Upper MidWest ![]() |
QUOTE(lmcchesney @ Jun 3 2004, 07:07 AM) I have used Permatex Extend and found this product to be very helpful. What is the difference in Permatex Extend vs POR-15 other than the resulting color of the finished area? L. McC I have wondered this same thing many times. Would love to hear the answer, but I think since we may be the only 2 guys who are NOT at or on their way to the WCC right now, we may never find out. (IMG:style_emoticons/default/beer3.gif) |
djm914-6 |
I've used both and found Extend to be ok. What makes the POR15 'system' a better product is it's top coat. If you look at the POR15 site, the product they call Metal Ready (or something like that) is about the same as the Extend product. Left alone, it will rust again... and fast.
aircooledboy |
Thank you Dave. (IMG:style_emoticons/default/beerchug.gif)
After reading the Por-15 site in more detail, it is starting to make sense to me now. |
lmcchesney |
My boys and I treated rust on the 914 six years ago. During this take down/rebuild I find all places treated with Extend to be intact and no recurrent rust.
L. McC |
tat2dphreak |
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region ![]() ![]() |
Extend is basically like OSPHO if I remember right, if it works as well as OSPHO, it's pretty damn good! I've used OSPHO on several things... it works well...
Lo-Fi Version | Time is now: 25th June 2024 - 06:39 PM |
