johnnyfast |
Newbie ![]() Group: Members Posts: 3 Joined: 24-May 11 From: westchester, ca Member No.: 13,114 Region Association: Southern California ![]() |
I have 3 problems that i need help with plz i have a 74 Porsche 914 1.8
1. the fuel pump will turn on as soon as i turn the key and it wont stop. is that normal? if not then how long is it suppose to stay on ? and how can fix it 2. My turn signals stay on after i turn the car off unless i return the lever to the middle position. is that normal? 3. the rpms are low to the point that sometimes it will turn off. how can i adjust? thanks johnny |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,702 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
I have 3 problems that i need help with plz i have a 74 Porsche 914 1.8 1. the fuel pump will turn on as soon as i turn the key and it wont stop. is that normal? if not then how long is it suppose to stay on ? and how can fix it 2. My turn signals stay on after i turn the car off unless i return the lever to the middle position. is that normal? 3. the rpms are low to the point that sometimes it will turn off. how can i adjust? (IMG:style_emoticons/default/welcome.png) 1. Depends on what you're running. Stock L-Jet FI? Carbs? Any modification we should know about? 2. Yes. It's a feature, not a bug. Most all European cars behave the same way, it's a "parking light" that you control with your turn signal lever. 3. Too many possibilities to list here. We need more info. When was the last time the valves were adjusted? Stock engine? Carbs? FI? (IMG:style_emoticons/default/driving.gif) |
johnnyfast |
I have 3 problems that i need help with plz i have a 74 Porsche 914 1.8 1. the fuel pump will turn on as soon as i turn the key and it wont stop. is that normal? if not then how long is it suppose to stay on ? and how can fix it 2. My turn signals stay on after i turn the car off unless i return the lever to the middle position. is that normal? 3. the rpms are low to the point that sometimes it will turn off. how can i adjust? :wttc: 1. Depends on what you're running. Stock L-Jet FI? Carbs? Any modification we should know about? 2. Yes. It's a feature, not a bug. Most all European cars behave the same way, it's a "parking light" that you control with your turn signal lever. 3. Too many possibilities to list here. We need more info. When was the last time the valves were adjusted? Stock engine? Carbs? FI? :driving: the engine is stock and the fuel system is fuel Injection. I just started working on the car it was sitting in my brothers backyard for a year and that the previous owner had it in the garage for 6 years or more not sure how many. so I'm kind of learning as i go. as far as I know nobody that has done any-kind of modifications on it. I replaced the plugs, distributor cap, and most of fuel system hoses, i took the gas tank off and cleaned it lots of rust inside, the fuel pump is under the tank and it just keeps pumping. i printed the hose diagram for the fuel system and reconnected all the hoses the right way. |
SirAndy |
74 Porsche 914 1.8. The engine is stock and the fuel system is fuel Injection. That would make it a L-Jet injection. The one system i know almost nothing about. Hopefully somebody else can help you out here. (IMG:style_emoticons/default/idea.gif) |
Mike Bellis |
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None ![]() ![]() ![]() |
mrgjones |
Member ![]() ![]() Group: Members Posts: 91 Joined: 23-November 09 From: Monterey Member No.: 11,062 Region Association: Northern California ![]() |
I have a 74 1.8 and the fuel pump stays on all the time. Not sure if this is supposed to be but it hasn't caused me a problem yet as the fuel just recirculates into the tank. One big issue with the l jet is the vacuum. Make sure there aren't any leaks. The head temp sensor is also a usual suspect for abnormal idle. If I remember correctly there is an idle adjustment on the throttle body.? I'd say you probably need to adjust your timing tho. Also flush out the engine oil a couple times. Some people on here even use a small amount of ATF with cheap oil (run for a few minutes, do not drive this way) to clean out all the gunk on a car that's been sitting. Can't vouch personally for that one tho.
Good luck |
johnnyfast |
thanks for all your info guys it helps. im learning about this car as I go along. i hope the pump doesn't burnt out on me. its very noise and it gets annoying after a while i guess i just have to turn up the radio lol
KaptKaos |
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest ![]() |
Your steering wheel isn't stock, so it doesn't have the canceling ring on it to turn off the directional.
(IMG:style_emoticons/default/welcome.png) (IMG:style_emoticons/default/thisthreadisworthlesswithoutpics.gif) BTW - your car is a '75. I'll show you next time. OT: Rough game tonight. (IMG:style_emoticons/default/barf.gif) |
Lo-Fi Version | Time is now: 23rd June 2024 - 12:56 PM |
