Do you have a ubiquitous gas smell?, and live in SoCal |
76-914 |
May 30 2011, 09:30 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,521 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
After reading Vysoc's thread re: chasing a gas smell, I thought that I would offer up this solution to local teeners. I have a gas sniffer that will locate any combustible gas leak as small as 3 parts per million. Yes, it will pick up a fart so it can't be used at (IMG:style_emoticons/default/poke.gif) Ron's shop. (IMG:style_emoticons/default/av-943.gif) (IMG:style_emoticons/default/lol-2.gif) It only takes seconds to locate a leak. I'm in the Temecula area. You could stop by most weekends or join us on a Dawn Patrol run and I'll bring it with.
SLITS |
May 30 2011, 10:39 AM
While I am in the mountains and you are in the flatlands, my flatus should reach you in far greater quantities than 3 ppm. (IMG:style_emoticons/default/icon8.gif)
The AQMD has a special alert for me. |
wertygrog |
May 30 2011, 08:06 PM
wertygrog Group: Members Posts: 428 Joined: 12-November 05 From: Long Beach, CA Member No.: 5,114 Region Association: Southern California |
Mine stinks of gas on left hand turns when I have more than half a tank of gas. I think it's the gas cap gasket but I'm not sure...
mgphoto |
May 30 2011, 08:22 PM
"If there is a mistake it will find me" Group: Members Posts: 1,341 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
I had the same problem, here is how I solved it.
Good luck Mike http://www.914world.com/bbs2/index.php?sho...=117213&hl= |
76-914 |
May 30 2011, 09:08 PM
Mine stinks of gas on left hand turns when I have more than half a tank of gas. I think it's the gas cap gasket but I'm not sure... PM me. I'll bring it to the Palomar run in June. Bring the car w < 1/2 tank. It's easier to find the source if the immediate area isn't saturated. It works like this: we could probably trace (IMG:style_emoticons/default/poke.gif) Ron all the way up the I 215 corridor clear to Kansas Street. But once we get to his shop we lose the trail because of the out gassing due to over saturation. |
wertygrog |
May 30 2011, 09:26 PM
haha okay sounds groovy!!
Mike D. |
May 30 2011, 10:26 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
My car smells of fumes so bad I have to change clothes after going for a drive!
Guess I should check into that.... (IMG:style_emoticons/default/dry.gif) |
jcambo7 |
May 30 2011, 11:02 PM
Senior Member Group: Members Posts: 1,664 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
Dr Evil is in So Cal now?
jim_hoyland |
May 31 2011, 12:31 PM
Get that VIN ? Group: Members Posts: 9,339 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
My car smells of fumes so bad I have to change clothes after going for a drive! Guess I should check into that.... (IMG:style_emoticons/default/dry.gif) Be careful.... Attached image(s) |
Lo-Fi Version | Time is now: 29th June 2024 - 03:01 AM |
