Mitch 914 |
Newbie ![]() Group: Members Posts: 27 Joined: 19-April 11 From: Beaverton Oregon Member No.: 12,956 Region Association: None ![]() |
stupid I know, I pull the inside cable, trunk pops up but what else do I have to do to release it? (IMG:style_emoticons/default/blink.gif)
stugray |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None ![]() |
Did it pop up 1 inch when you pulled the cable?
If so, it has a secondary latch like all cars in the front. If it wont pop up at all, try having someone push down on it while you try to pull the cable. If THAT does not work, the cable is broken or stuck, and you have to remove the front bumper. You will find a hole that you can access the latch with a screwdriver. Stu |
Mitch 914 |
Did it pop up 1 inch when you pulled the cable? If so, it has a secondary latch like all cars in the front. If it wont pop up at all, try having someone push down on it while you try to pull the cable. If THAT does not work, the cable is broken or stuck, and you have to remove the front bumper. You will find a hole that you can access the latch with a screwdriver. Stu Thanks Stu that is what I am trying to find? the secondary latch? |
championgt1 |
Don't embarrass me Filmore! ![]() ![]() ![]() ![]() Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest ![]() |
Directly in the center of the hood there is a latch.
Mitch 914 |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
How 'bout you grab a flashlight, turn it on, and get down there and look at it? It's a little "paddle" thingy just under the lip of the hood, and you lift on it. Might have to give the hood a gently up-and-down wiggle to get it to come free.
The Cap'n |
detoxcowboy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa ![]() |
Not much unlike unhooking a Bra, the first time you have to peek..
Jeffs9146 |
Ski Bum ![]() ![]() ![]() ![]() Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 ![]() |
Just grab the front of the hood and squeeze the latch to open!
Mitch 914 |
Just grab the front of the hood and squeeze the latch to open! Thank you it worked!!!!!!!!!! (IMG:style_emoticons/default/piratenanner.gif) |
KELTY360 |
914 Neferati ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,040 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest ![]() ![]() |
All right! Now that you've got it opened you can fill that tank with gas and (IMG:style_emoticons/default/driving.gif)
Mitch 914 |
Just grab the front of the hood and squeeze the latch to open! Thank you it worked!!!!!!!!!! (IMG:style_emoticons/default/piratenanner.gif) Thank to all---------------------you are great (IMG:style_emoticons/default/beerchug.gif) |
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
do you know matt?
0396 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California ![]() |
How 'bout you grab a flashlight, turn it on, and get down there and look at it? It's a little "paddle" thingy just under the lip of the hood, and you lift on it. Might have to give the hood a gently up-and-down wiggle to get it to come free. The Cap'n (IMG:style_emoticons/default/smile.gif) |
Jacob |
Member ![]() ![]() Group: Members Posts: 131 Joined: 12-February 08 From: Mansfield, Oh Member No.: 8,705 Region Association: Upper MidWest ![]() |
Not much unlike unhooking a Bra, the first time you have to peek.. With practice, you can do it with one hand. (IMG:style_emoticons/default/wink.gif) |
Lo-Fi Version | Time is now: 26th June 2024 - 05:42 AM |
