need webers 40IDF"s or Empi 40"s, work work |
Mitch 914 |
Aug 1 2011, 05:59 PM
Newbie Group: Members Posts: 27 Joined: 19-April 11 From: Beaverton Oregon Member No.: 12,956 Region Association: None |
I have all new linkages and gaskits but my webers are full of water and rusted can not rebuild. I am in a hurry because this little project has turned into a nightmare! I need only the carbs. Who sell just the carbs??????????????Thanks in advance. (IMG:style_emoticons/default/barf.gif) I am done with this, just want new carbs. If I have to I will buy the kit?
dirk9141973 |
Aug 1 2011, 07:54 PM
Unregistered |
I have all new linkages and gaskits but my webers are full of water and rusted can not rebuild. I am in a hurry because this little project has turned into a nightmare! I need only the carbs. Who sell just the carbs??????????????Thanks in advance. (IMG:style_emoticons/default/barf.gif) I am done with this, just want new carbs. If I have to I will buy the kit? I bought a set of EMPI 40's from AA $499 they have worked out for me ?? |
VaccaRabite |
Aug 1 2011, 07:56 PM
En Garde! Group: Admin Posts: 13,629 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I have all new linkages and gaskits but my webers are full of water and rusted can not rebuild. I am in a hurry because this little project has turned into a nightmare! I need only the carbs. Who sell just the carbs??????????????Thanks in advance. (IMG:style_emoticons/default/barf.gif) I am done with this, just want new carbs. If I have to I will buy the kit? Are you sure they can't be rebuilt? New carbs are not of great quality. the older ones are better. Everything in a set of IDFs can be serviced. I've seen grody carbs that cleaned up nice. Zach |
tscrihfield |
Aug 1 2011, 08:17 PM
Drive Fast and Take Chances Group: Members Posts: 643 Joined: 8-September 10 From: Amelia Ohio Member No.: 12,156 Region Association: None |
I have all new linkages and gaskits but my webers are full of water and rusted can not rebuild. I am in a hurry because this little project has turned into a nightmare! I need only the carbs. Who sell just the carbs??????????????Thanks in advance. (IMG:style_emoticons/default/barf.gif) I am done with this, just want new carbs. If I have to I will buy the kit? I have a set of Spanish webers. $480 to you! They were running on a 2.0 about a year Ago. Thomas |
Root_Werks |
Aug 2 2011, 08:50 AM
Village Idiot Group: Members Posts: 8,525 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
There has been quite a bit of chatter about HPMX carbs on thesamba lately. The early versions seem to have quite a few issues, but since Art was able to set them straight on a few major items, seems like most can just slap them on and go. I think the version 2 came out last year?
Something like that. I've also heard you want buy your HPMX carbs, then send them to Art so he can re-do them. This is for new carbs. BUT, I've heard tons of guys having good luck with them lately. The quality must be getting better. (IMG:style_emoticons/default/confused24.gif) Shafts wear and yes you can get them rebuilt, but any used carb will likely have vac leaks up the ying-yang. My 2 cents would be on HPMX units unless I could score a good set of low mileage webers. |
VaccaRabite |
Aug 2 2011, 10:45 AM
Vac leaks up the yingyang? I am using old Spanish Webers that needed a total rebuild. They don't have vacuum leaks that I have been able to find (and I have looked closely). I have other usual carb problems (shit fuel, trash in the passages, etc) but they do not have vac leaks. My carbs are easily 20 years old and were way grody when I got them. They cleaned up very well. With better air cleaners I bet I would solve many of my problems.
The key is that nomatter if you buy new or used, you are going to need to rebuild and probably rejet them. It's not just a bolt on solution. Zach |
Drums66 |
Aug 2 2011, 11:14 AM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
........All the in the know cats say (Dells) ....if you are going to really do that!
(IMG:style_emoticons/default/idea.gif) carb thing, (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/bye1.gif) |
Lo-Fi Version | Time is now: 4th January 2025 - 10:03 PM |
