blaize |
Newbie ![]() Group: Members Posts: 39 Joined: 31-March 04 From: New Orleans Member No.: 1,866 ![]() |
Anyone know of a torque spec. for the head studs? Not to install the heads, but to install the studs into the case. None of my books list one. I suppose I will just put them in damn tight w/red locktite. the spec when installing the heads is only 26 and I know they get much tighter once the engine is warm so around 50 (hand tight) should be safe but if anyone has heard an actual # for this, letta brotha no.
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
i suspect that spec is shown in the factory workshop manuals. before i go dig through everything to find where i've stored mine, you might mention what kind of engine you're working with -- 1,7; 1,8; 2,0; /6; Chevy, Ford ...
Mark Henry |
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada ![]() |
I don't know if there is a spec for the head studs, some of the studs might go right though the case. Put them in so the shoulder is below the mating surface and use a good dab of locktite.
If they can be torqued I doubt if it will be any more than a head nut. |
Lo-Fi Version | Time is now: 20th June 2024 - 06:08 AM |
