How do I get this dang nut off? 911 engine mount!, Got it!! Slits is da MAN!!! |
hwgunner |
Aug 14 2011, 08:50 PM
914 Parts @ Discount Prices 800.321.5432 Group: Members Posts: 1,714 Joined: 11-November 04 From: Santa Maria, Ca Member No.: 3,095 Region Association: None |
So here is a picture of one nut that I can remove. I am trying to remove the engine mount from a 2.7. This is the nut at the top right if you are facing the motormount. Seems pretty straight forward but my socket and wrench do not fit in the space and the box wrench just does not have quite enough depth or angle. Do you need a shallow socket or am I missing somthing??
This is going to be a long build if I can't even get bpast a damn nut on the tear down. oh well (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/blink.gif) Its the one in the center shrouded by the mount. |
SLITS |
Aug 14 2011, 09:02 PM
1/4" breaker bar and socket. I don't remember if the same combination of 3/8 will work.
Put socket on .. attach breaker bar and loosen. Hopefully it will spin by hand once broken loose. Once you remove the other 3 you can pull on the nose piece as the nut comes off. |
hwgunner |
Aug 14 2011, 09:19 PM
1/4" breaker bar and socket. I don't remember if the same combination of 3/8 will work. Put socket on .. attach breaker bar and loosen. Hopefully it will spin by hand once broken loose. Once you remove the other 3 you can pull on the nose piece as the nut comes off. 3/8 works but is a bit tight. I can see where a 1/4 would be easier. Slits, I knew you would get me going when I saw you posting. Thanks |
ConeDodger |
Aug 14 2011, 09:53 PM
Apex killer! Group: Members Posts: 23,825 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Admins please move this to the Sandbox. I am not sure it is appropriate for Jonathan to ask how to get his nut off in the Garage... (IMG:style_emoticons/default/evilgrin.gif)
Elliot Cannon |
Aug 14 2011, 10:12 PM
Admins please move this to the Sandbox. I am not sure it is appropriate for Jonathan to ask how to get his nut off in the Garage... (IMG:style_emoticons/default/evilgrin.gif) Especially with help from broke back mountain man. (IMG:style_emoticons/default/av-943.gif) |
Cap'n Krusty |
Aug 14 2011, 10:18 PM
Somebody still owns a 12 point socket?
The Cap'n |
MoveQik |
Aug 14 2011, 10:19 PM
What size wheels can I fit? Group: Members Posts: 4,654 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
Slits??? You listened to Slits?? Talk about rolling the dice....
hwgunner |
Aug 14 2011, 10:24 PM
OK, I got my nut off. No need to kick a guy when he is down.
hwgunner |
Aug 14 2011, 10:25 PM
Somebody still owns a 12 point socket? The Cap'n The way I use tools, or don't as the case may be, I will never wear these out! (IMG:style_emoticons/default/KMA.gif) |
ConeDodger |
Aug 14 2011, 11:00 PM
Ok that's a new one... A guy gets his nut off and feels down? (IMG:style_emoticons/default/blink.gif)
hwgunner |
Aug 15 2011, 12:04 AM
Ok that's a new one... A guy gets his nut off and feels down? (IMG:style_emoticons/default/blink.gif) I guess I was down because I couldn't get it off....... Ok, Ok you are right! (IMG:style_emoticons/default/piratenanner.gif) |
markb |
Aug 15 2011, 10:55 AM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
Hmmm, sounds like it was a good thing I was camping with the girlfriend for the weekend. Jonathan had his "tools" out. (IMG:style_emoticons/default/lol-2.gif)
hwgunner |
Jun 2 2012, 11:32 AM
Sorry, posted this thread on another thread to help a guy out and then re-read this thread and couldn't stop laughing. BTTT for the grins. (IMG:style_emoticons/default/sheeplove.gif)
jonathan |
Lo-Fi Version | Time is now: 25th November 2024 - 07:45 PM |
