2.0L tin removed, oil pressure sensor broken off |
jimkelly |
Aug 18 2011, 11:15 AM
Delaware USA Group: Members Posts: 4,969 Joined: 5-August 04 From: Delaware, USA Member No.: 2,460 Region Association: MidAtlantic Region |
i tried to drill a hole in the center of what is left of the oil press sensor - this thing seems to be made of kryptonite ???
i also had to drill out some tin screws - will try to extract as many as i can. jim Attached thumbnail(s) |
Jeffs9146 |
Aug 18 2011, 11:28 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
use a dremmel with a carbide tip then a screw extractor.
76-914 |
Aug 18 2011, 11:37 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,647 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
You need to drill it thru, first. Then the extractor. I prefer the spiral to the 4 cornered extractor. Especially when working with softer metals.
jimkelly |
Aug 18 2011, 11:57 AM
spiral
r_towle |
Aug 18 2011, 01:11 PM
Custom Member Group: Members Posts: 24,661 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
if you drill out the oil pressure sensor, you will be opening up the case on that motor to clean up inside.
So, I vote to procrastinate and wait until you have nothing left to do but drill out that piece, one the bench, with a jig and drill press, and its a nice day with a good cold beer. When in doubt, procrastinate. Rich |
MartyYeoman |
Aug 18 2011, 01:23 PM
Senior Member Group: Members Posts: 1,527 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
if you drill out the oil pressure sensor, you will be opening up the case on that motor to clean up inside. (IMG:style_emoticons/default/agree.gif) Do it later when you have more control over the situation. Marty |
JawjaPorsche |
Aug 18 2011, 01:25 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
I had my oil pressure sender to break about ten years ago. I was afraid to drill because I was afraid of metal shavings in the motor. So I got a good sheet metal screw with permagasket and plugged the hole. Not the idea thing to do but it worked for me.
jwc914 |
Aug 18 2011, 09:51 PM
Newbie Group: Members Posts: 34 Joined: 16-August 11 From: san jose,ca Member No.: 13,447 Region Association: None |
I had my oil pressure sender to break about ten years ago. I was afraid to drill because I was afraid of metal shavings in the motor. So I got a good sheet metal screw with permagasket and plugged the hole. Not the idea thing to do but it worked for me. |
76-914 |
Aug 19 2011, 08:29 AM
if you drill out the oil pressure sensor, you will be opening up the case on that motor to clean up inside. So, I vote to procrastinate and wait until you have nothing left to do but drill out that piece, one the bench, with a jig and drill press, and its a nice day with a good cold beer. When in doubt, procrastinate. Rich Use a good shop vac when drilling. The flutes will direct the shavings out. The vacumn will keep the shavings from falling into the engine. Or, if your really paranoid, flip the engine and drill it out from beneath and let gravity work with the vacumn. |
Lo-Fi Version | Time is now: 26th December 2024 - 09:02 PM |
