Fuel pump rubber "snubbers", do these act as a ground? |
ChrisReale |
Jul 9 2004, 12:21 AM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
When my fuel pump was shorting out on me, I realized the pump was not fully screwed down against the two rubber bumpers. Do these act a s a ground as well as protect it from vibration? Since I tightened the pump down, I have had no issues what so ever.... (IMG:style_emoticons/default/confused24.gif)
Andyrew |
Jul 9 2004, 12:40 AM
Spooling.... Please wait Group: Members Posts: 13,377 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
Well, maybe it was the vibration that shorted it out?
I dont think that they are used as a ground... Andrew |
Mike D. |
Jul 9 2004, 12:53 AM
OK, It runs now, and pretty good too! Group: Members Posts: 1,448 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
No ground in the mounts. Your fuel pump should have a plug with a + and -.
My '74 fuel pump was also shorting out a few years ago. It would pop the fuse on the relay board. I found that the wires in the harness had shorted together due to the heater valve cable (that was disconected at the time) had bounced around and touched the fuel pump wires. The pump was relocated by a PO and the wire connection was bare. I just ran new wires... -Mike D. |
SirAndy |
Jul 9 2004, 10:04 AM
Resident German Group: Admin Posts: 41,945 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
QUOTE(Mike D. @ Jul 8 2004, 11:53 PM) No ground in the mounts. Your fuel pump should have a plug with a + and -. (IMG:style_emoticons/default/agree.gif) what he ^^^ says ... your short is somewhere else, probably the connector plug and/or wires. Andy |
Lo-Fi Version | Time is now: 27th December 2024 - 11:27 AM |
