peteyd |
Senior Member ![]() ![]() ![]() Group: Members Posts: 715 Joined: 27-March 08 From: Elora, Ontario, Canada Member No.: 8,858 Region Association: Canada ![]() |
Valy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California ![]() |
You can use the single ended one. It grounds itself through the body so the brown wire should be left unconnected.
peteyd |
Ok great!
Thanks Valy! |
Valy |
Ok great! Thanks Valy! One more thing: There are 2 version of this single ended switch: 1. will make contact and light up when the pressure drops but will shut-off afterwards. Try to avoid this. ![]() 2. will make contact and when the pressure drops and will remain that way until you press the reset switch. Note the black bump next to the electrical contact. Its a rubber boot over the reset switch. This is the one you want for your safety as the pressure drop will not go unnoticed. ![]() |
kenrinc |
Newbie ![]() Group: Members Posts: 10 Joined: 12-February 09 From: BayArea, CA Member No.: 10,045 Region Association: Northern California ![]() |
Sorry to stir this one up but I can't believe I even found a post on it! Everyone has been telling me different.
I got a new master cylinder as the OP did and my original was a 2 prong switch. I just swapped out the single prong on my new one for the old 2 prong because I assumed the old one was more complex. The 2 prong sensor does not have a reset button. I can't seem to stop the brake warning lights from flashing and people keep telling me to reset the switch. I can't reset the switch because there is no switch!! Its just a plastic divider and I have not been able to figure out how to reset it. One person mentioned that there was some procedure of pressing the pedal all the way down or something? After reading this I'll just install the single prong sensor since I know I can reset it. Ken- |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,002 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
This is the one you want for your safety as the pressure drop will not go unnoticed. I've experienced the pressure drop once. Trust me, it won't go unnoticed... Something about the pedal going all the way to the floor and the car pretty much not slowing down at all kinda makes you notice. I pumped the pedal once, and had brakes. But I blew my braking point for turn 1, and did the rest of the lap kind of slowly until I could exit the track... --DD |
Lo-Fi Version | Time is now: 1st July 2024 - 01:23 PM |
