Front main seal removal, How do you get the thing out? |
bigkensteele |
Sep 18 2011, 02:47 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
I made a nifty little C shaped tool and pulled the fan hub with no problem. Managed not to lose the woodruff key. Now, I am scratching my head trying to figure out how to actually extract the old seal without damaging my case. Tried several searches without luck. Anyone? (IMG:style_emoticons/default/confused24.gif)
PRS914-6 |
Sep 18 2011, 04:16 PM
Excellence Magazine Project 914 3.6 Group: Retired Members Posts: 1,278 Joined: 20-May 06 From: Central California Member No.: 6,031 Region Association: None |
You didn't say if the engine was in or out.....Try driving a sheet metal screw in it and then you can grab it or use it to pry on
bigkensteele |
Sep 18 2011, 04:21 PM
Got it. I used a large screw driver, with a hard piece of plastic between the screwdriver and the case, and pried it out. Took a bit of force, but once it gave, it popped right out.
Engine is out of the car on a stand. Thanks, Ken |
get off my lawn |
Sep 20 2011, 11:20 AM
Member Group: Members Posts: 168 Joined: 18-August 11 From: west coast Member No.: 13,462 Region Association: None |
sawzall woulda worked too. :-)
914werke |
Dec 9 2011, 09:47 AM
"I got blisters on me fingers" Group: Members Posts: 10,535 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Did you have the shroud off ? is it possible to do by just removing the Impeller?
Lo-Fi Version | Time is now: 22nd September 2024 - 12:09 PM |
