RiqueMar |
Enrique Allen Mar ![]() ![]() ![]() ![]() Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California ![]() ![]() |
Putting on the CV's, which are rebuilt (possibly upgraded? (IMG:style_emoticons/default/confused24.gif) ), and I noticed these don't have the slots for the roll pins? Can I just take off this top part and drill and insert the roll pins?
Also, these look to be different CV's, as all the other ones I have in my possesion only have 4 holes for the bolts on the axle side, and these have 6 holes?? What the hell? I swear, it's always 'something' when I move onto a new section of my car. (IMG:http://www.914world.com/bbs2/uploads_offsite/i16.photobucket.com-9478-1316805816.1.jpg) |
messix |
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest ![]() |
dowls
RiqueMar |
JRust |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,309 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest ![]() ![]() |
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Hard to tell from the pics, but all the holes look to be the same size. I also don't see the machined lip for the gasket to set in. Could that be a type I cv? Is the cv on backwards? Is that even possible?
scotty b |
rust free you say ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None ![]() |
EARLY 911's had 6 bolt cv's. Might want to keep that in mind too. Eric could probably tell how how to positively ID them
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
6 bolts ... 911
Measure the bar length ... It will be less than 20" if they are stock 911. (bar length = the length of the actual CV beam, not counting the CV joint) Can't remember the diameter of the CV joint, but I want to say on the order of 104-108 mm. Probably wrong on that one. Check the fit against your transmission flange unless they been changed to 911). I assume you went 5 lug ... if they rear hubs are 914 redrilled, the splining on the axle stub will be different. |
RiqueMar |
6 bolts ... 911 Measure the bar length ... It will be less than 20" if they are stock 911. (bar length = the length of the actual CV beam, not counting the CV joint) Can't remember the diameter of the CV joint, but I want to say on the order of 104-108 mm. Probably wrong on that one. Check the fit against your transmission flange unless they been changed to 911). I assume you went 5 lug ... if they rear hubs are 914 redrilled, the splining on the axle stub will be different. My rears hubs are redrilled for 5-lug, however, the splines fit directly in. (IMG:style_emoticons/default/idea.gif) Upgraded axles and CV's??? |
mskala |
R ![]() ![]() ![]() Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None ![]() ![]() |
Pic of all 911 types from other board:
RiqueMar |
Wow! That's a great photo and break down!
Checking now! |
RiqueMar |
Lo-Fi Version | Time is now: 25th June 2024 - 11:48 PM |
