? whats needed to 1.7 block and heads to install 94mm P&Cs |
jimkelly |
Oct 22 2011, 04:39 AM
?? whats needed to 1.7 block and heads to install 94mm P&Cs ??
i ask because i have a set of 94mm P&Cs for sale i a potential buyer has asked me this very question. http://www.914world.com/bbs2/index.php?showtopic=148938 between you and me - i am pretty sure the block and the heads will need machining. will bigger P&Cs in a otherwise stock 1.7 bring more HP? thanks jim ** of course being in sales, i said, "hell yeah" " they will fit right in, no problem" but now i am feeling guilty about that. damn, i hate having a conscience : ) |
jaxdream |
Oct 22 2011, 07:48 AM
Senior Member Group: Members Posts: 974 Joined: 8-July 08 From: North Central Tennessee Member No.: 9,270 Region Association: South East States |
From what I've read that others more knowledgeable than me , say block no need , heads definately .Check out Jakes web , might give some specs .
As far as sales go , well ......... Jack |
914rat |
Oct 22 2011, 12:01 PM
Member Group: Members Posts: 279 Joined: 3-July 06 From: Maryland Member No.: 6,362 |
The spigots on the case are the same on all cases.The heads on a 1.7 will need to be opened up to accept the larger cylinders.
How much for the P&C's ? Anything you need in trade? |
jimkelly |
Oct 22 2011, 03:25 PM
thanks guys.
and i am pretty sure 1.8 heads can be used without modification? jim |
VaccaRabite |
Oct 22 2011, 06:32 PM
En Garde! Group: Admin Posts: 13,616 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
Block will be fine but the cylinder registers need to be checked to see if they are collapsing.
Heads will need to be cut to accept bigger cylinders. If you have 1.8 heads they should work fine. Zach |
bam914 |
Oct 22 2011, 06:55 PM
Member Group: Members Posts: 342 Joined: 23-November 03 From: Atlanta, Ga Member No.: 1,378 Region Association: None |
The pin height on the 2.0L pistons is less then the 1.7-1.8. If he plans to use the 66mm stroke crank he will have a huge deck height.
jimkelly |
Oct 25 2011, 07:10 AM
so it sounds like with these P&Cs.
1- any block can be used. 2- 1.8 and 2.0 heads can be used unmachined. 3- 2.0 crank and rods should be used. ??? |
Jake Raby |
Oct 25 2011, 07:45 AM
Engine Surgeon Group: Members Posts: 9,398 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
Detailed article on this subject can be found on my forums.
Lo-Fi Version | Time is now: 26th December 2024 - 05:09 PM |
